  • Replies 75
8 cars is a min i think.
Minimum for a club is 6, at a cost of $100 per entrant.
If people want to enter their car as a private entrant, the cost is $120.
pdf of the entry form is available for download
here
yer, but there are other costs... we aint getting a normal entry style of thing :D
we paying a bit more each, so we can get some extra space, with 6 people it's just too expensive for everyone to be able to cover, mates of mine have done it with 6 and it hurts the good ole hip-pcoket quite well :headspin:
If my car is ready, i can put it in if it's deemed worthy. But not too keen on paying $100 for my car tho... didn't know it was that expensive :)
It'll be more than $100... probably about $150 per person.
a BBQ would maybe drop it by $10 per person.
I'll do a tally this weekend.
I believe we have 8-9 people now (got a few PM's also)
So i'll see where it stands... FA dont seem to be doing a stand... might have to talk to a certain someone and try get him to put his GTR with us ;)
If u guys need sum extra no.'s i hav an R32 GTST with a vertex front bar side skirts, no rear wing, 18' rims, pretty low and a FMIC.
Not the showiest car goin around but very neat.... just here to help make up the no.'s if u need them otherwise see u guys there.
cheers
whack a pic up in this thread if you could mate :rolleyes:
If its real low thats pretty cool.
I think we might hve about 10 people now :)
more detail to come
Ok, the 100% interest (guys that actually have thier cars now) is like this
DJ_L3thal
KamikazieR33
abcent
krzysiu
Much
m_rickards
And my car. Making 7 people that actually have cars to enter.
Im not counting guys that aint got cars as many things could delay them getting 'em.
And there is a question on two more... Leewah's GTR, and Nige's Supra.
But they are not yet confirmed so we wont count them either.
What do you guys wanna do? its upto all of you.
Cost will probably be around $140 per entry.
- ash
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
