Hi all , recently killed another battery which was a Century NS60S 430CCA claimed standard replacement .
Never liked these because I thought they were too small and more like a 4 cylinder battery .
I went to Batteries Direct at Peakhurst in Sydney because a friend works nearby and recommends them .
I wanted a battery more like 530 CCA and one that can fit is a Century EB58 which is intended for Fords .
Length wise basically same as NS60S but wider and fits between the alternative mounting rod holes .
Also these are a large pole battery unlike the small ones in the previous battery , never liked those particularly the smaller earth one .
My earth lead had been remade to a larger one with the std two hole fitting reused and an eye fitted to the battery end .
I bought new terminals with rings machined in their holes to bite in a bit better . They connect to the cables with a stainless eye bolt .
I had a spare positive cable from a wreck so I cut the outer part of the pressed clamp off and used the original hole , enlarged , to bolt to the new terminal .
Also bought a new clamp bar because the old one isn't long enough .
So now have a wider 540CCA battery which should crank a cold RB25 over a bit better this winter .
Take care cheers A .
Actually people I stuffed up with which Century range battery I bought . If I'd looked at the Ultra Hi Performance instead of the High Performance range I could have had a 620 rather than 540 Cold Cranking Amp rating in the same physical size . Bugger ...
A .
Almost certainly more expensive and a bit heavier , sounds like more lead in its plates . I think from memory the Century Ultra High Performance version is called a 68 but check before buying . Physically same dimensions as the High Performance 58EB I have .
An 820CCA battery would no doubt start an RD28 Diesel six . What battery is your one ?
A .
https://parts.cat.com/en/catcorp/premium-high-output/230-6368
Had the cut/move small locating tab, new bracket across the top and usual cable/terminal upgrades for bigger posts. Think it was $160 from memory
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
