Hi everyone, Greetings from Darwin, that's my first post here - so... I bought my first Skyline last week(r33 gts-t) and it started blowing blue smoke couple days ago every time when I've been driving steady for a while and then put my foot down to 4000-5000rpms on 1st and 2nd gear.
Also all the oil breather hoses were either broken or blocked and oil was leaking everywhere and got oil pressure warning light all the time, anyway replaced these hoses and serviced the engine(no i didn't overfilled with engine oil) and now it's blowing blue smoke. Pulled the turbo/intercooler pipes off and there is fair a bit of oil there but turbo is all good, no odd shaft play. Could it be the oil rings ? Cheers
https://www.sau.com.au/forums/topic/459023-r33-rb25det-blowing-blue-smoke/
Is that with the blue ring coming out of rocker cover ? Pulled that hose off and tried to blow air through the valve, it works only one way, can suck air out from engine but can't blow it back.
PCV looks okay, looks fairly new
You can test if you want, its just a check valve so you should be able to blow through it in one direction and not the other
Catch cans arent really necessary on stock or near stock cars, im not sure what is done to yours
If that's how to test it then yes it works.
I'm thinking that because of that one blocked breather hose on top of rocker cover was completely crunched that no air could get through, engine had too high oil pressure all the time and old owner just kept driving it, so it blew the turbo seals coz it seems to have bit too much oil in intake?
Yeah it's near stock:
3" cat back exhaust
Front mount intercooler
Pod filter
stock turbo and turbo controller at the moment
Does the oil level drop now that youve fixed it? Im wondering if its just burning off oil that was in the wrong spot because it wasnt breathing properly. May be turbo but its good to rule out cheaper/easier things first
Check your inter-cooler piping for oil, especially at the lowest point.
We had exactly the same issue on a R32 GTR after a track day, found the blowby oil got into the intake piping when we pulled the intercooler off, every time we got the revs up hard and onto boost it was smoking.
Cleaned out the oil, problem went away, then fitted a catch can to stop it happening again, it never returned.
Thanks guys, will clean the intercooler and piping out soon as i got time + replace spark plugs after it's not burning oil anymore. Definitely will fit a catch can, redirecting oil to intake seem like a bad idea.
Alright, now i have a boost leak so i pulled some hoses/pipes off to see what's going on. Found that someone has blocked off the bov with a piece of tinnie, what's the go with that ? See picture below :
Built a pressure tester to find the boost leaks, got rid of all the leaks but still feels like boost leak and lack of power on higher revs. So i pulled off the turbo, intercooler, pipes/hoses. Found some pieces of metal inside the intercooler and engine oil has turned black(just serviced about 600km's ago). Turbo has a slight shaft play inside-out but not side to side, cold side wheel looks a bit rough. Drained all the engine oil, luckily didn't found any metal pieces from oil. Apparently turbo was just replaced before i bought the car so might it be that f**kers blew the old turbo up and didn't clean the intercooler??? Still doesn't explain why I get 15psi of boost and that sucking noise like a boost leak+ stalling when turbo is supposed to kick in. Might need to start looking for a new turbo... :rant:
Yeah mate, cleaned the intercooler and piping with degreaser and hosed all the dirt out. I didn't put anything back together because my concern now is what kind of damage all that has done already. Been just browsing different topics here for hours already, reading about Kinugawa turbos at the moment, probably takes me another couple days to finish that thread lol.
Also i just remembered now that when i was doing the boost leak test, @10psi oil dipstick popped out and released all the pressure which seems bit odd on such low pressure.
Forgot to take a picture but here's a picture from Google how i did the pressure test:
Still trying to figure out whats wrong with it, made a short video of that whistle sound.
https://www.youtube.com/watch?v=wVQwkeTv5j0
Wanna get my car running properly again, might go for a new turbo if can't find the problem soon.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
    • Not yet quite as bad as what we've seen a Jim Berry clutch do in an R32 GTR though when it decided to cut a chassis rail in half... Still very very gnarly and a great reason to avoid.
