Also i just remembered now that when i was doing the boost leak test, @10psi oil dipstick popped out and released all the pressure which seems bit odd on such low pressure.
Forgot to take a picture but here's a picture from Google how i did the pressure test:
Getting blow by on the rings. If motor was cold then could be nothing. You'd have to comp test a warm motor to see though.
Thanks for replying.
Engine was warm when i did it. Getting a compression tester from ebay but i hope you're wrong mate, wouldn't want to pull motor apart at the moment.
Edited by GhostK
Get a leak down tester and check it properly.
DO NOT by a ebay leak down tester...i did and spent a whole evening modding it to work properly.
They are suppose to have a 1mm orifice to work correctly, the ebay one didn't and i had to make one to get the right readings.
At the moment i just bought the compression tester but you're right, none of the leak testers on ebay doesn't seem to have orifice on. Did you filled the middle pipe with epoxy or something and drilled the 1mm hole through ?
Removed the inlet hose, cut a thread into the passage, drilled a 1mm hole in a grub screw and loctited it in.
I also pissed off the % gauge and used a normal 100Psi gauge.
95Psi reading when its set at 100Psi translates to 5% leak down
If your compressor wont go to 100Psi, do the test at 50Psi and double the resulting pressure decrease to calculate the true percentage.
So if you test at 50 PSI and the gauge reads 45Psi, your 5Psi drop means a 10% leak down.
Righto, thanks.
Compression test should show if there is something dodgy going on and then i would have to rebuild the engine anyway but if it doesn't I'll get a leak down tester.
Yeah i know it's me again....
Anyway, got the compression tester today and here's why I've been getting mashed by Fords lately.
Cold, dry test
1) 135 psi
2) 50 psi
3) 150 psi
4) 140 psi
5) 135 psi
6) 135 psi
Cold, wet (teaspoon of oil) test
1) 168 psi
2) 90 psi
3) 200 psi
4) 180 psi
5) 178 psi
6) 178 psi
Not sure if to go and buy a carton of bundy or start pulling the motor apart... on a side of the street coz don't have a garage or not even enough room in a yard for a car.
I reckon it's too much of a difference between cyl 3 and all the others too.
If i already have to do the job i might as well get a whole rod and pistons kit, just don't know yet what size to take as that engine was already swapped with original one 2 years ago and not sure if any internal work was done back then or no.
I've got 3 or 4 used OEM pistons (had at least 2 with broken ringlands, would have to check the rest) if you want a cheap option. Also have a brand new set of OEM rings in stock size - bought then decided to buy forged pistons.
Thanks heaps mate, i just lost my long term job today so everything is going pretty bad for me lately...
You wanna pm me the price you would take for the pistons/rings you have there ?
  • 1 month later...
Been exactly month now since last post, finally i got a house with a good size yard so i pulled the motor apart.
Cylinder 2 piston that gave me 50psi (dry)
If i started taking the rings off Cyl 1 and 6 piston ringlands gave up too.
Luckily I got 3 spare OEM used pistons witch gives me a good set of 6 all together + new OEM ring set.
But I'm bit concerned now if i'm already spending that much money to freshen up the head and the block(head is already in engineering shop) and finally decide to aim 250-300rwkw I might end up with another broken ringland ?
So you're now in the same position we were earlier in the year - 2 pistons with cracked ringlands, motor in bits, how far to go (how much to spend). We bought oversize forged pistons and had the block bored to suit, but it added close to $1500 to the build cost - the bores had already been honed to refit the stock pistons and had to go back in for the rebore. This was why I had a new set of OEM rings. It will be more a financial decision than anything. Not sure if your mentioned earlier in the thread, but what are you using the car for? Ours is a track car so spends a lot of time working hard - this is what pushed us towards forged pistons.
It's just gonna be a street car, no track days whatsoever.
What caused these broken ringlands I reckon was a very bad tune in bad hands of previous owners. If i got that car it had a hole in a pod filter, O2 sensor not connected, different spark plugs in every cylinder, very low engine oil + very dirty oil, blocked breather hoses, vacuum leaks, thermostat drilled through so engine never ever warmed up etc etc.
So IF i decide to put it back together with these old pistons hopefully i find a good tuner(hard to find up here) after installing power FC and it SHOULD last but yeah...
Also depends what the bloke in engineering shop reckons next week when i show him the bottom part of that motor.
Oh and by the way the pistons i got from you went clean in heavy duty degreaser in 20 minutes. :wave:
In a meanwhile, the pistons from my engine been soaking for 12 hours and only the sides are clean...
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
