Fs [nsw]: R32 Gtr Tarmac Rally Prepped With Rego. Big Brakes/suspension/reliable 340kw/does Skids/bitchez Will Flock
1990 R32 GTR
Originally imported specifically for Targa Tasmania and originally prepped by RacePace and Meridian Motorsport.
I’m the second Aussie owner. To clarify, number plates are from my old RX3, the GTR *DOES NOT* have an injected bridgeport 12a.
8 months rego. Registered as a coupe, so no back seat required. No folding front seats and has OE belts to keep the po-po happy.
2x Velo GPT-2 fixed back seats mounted to alloy brackets. Very low driving position, I’m 6’2” and have >150mm from helmet to roof, plenty of room for a cage + padding
2x 3” 6pt MotorQuip harnesses with OE belts still fitted for rego
Stripped interior, no holes cut other than bolt holes in floor from now-removed bolt-in cage. Alloy centre console covering G-sensor with battery-cut mounted. No trim from B-pillar back, no roof trim. Door trims remain untouched (electrics work) All sound deadening removed from entire car
Autometer oil pressure gauge in centre dash, all OE gauges work except oil pressure (obviously now use mechanical gauge)
320kph Nismo speedo
Haltech controlled two stage shift light mounted on steering column
2wd/4wd switch in centre dash
TerraTrip 303 PLUS wired into cabin. Not currently installed but will be supplied (bracket bolts to glove box area so no holes in dash etc)
Removed rear wiper
6pot/355mm forged calipers with 32mm 2pc directional rotors on front (http://www.nengun.com/app/brake-caliper-kit) (http://www.app-top.jp/brake/caliper/index.html)
4pot/330mm forged calipers with 2pc directional rotors on rear (OE handbrake)
Braided hoses. OE ABS working. Super DOT4 fluid. QFM pads at both ends (same size pads as Brembo, so easy to source pads)
Stops like a mofo…
Ex-WTAC custom Bilstein coilovers modified with MCA Gold external canisters (bump + fast/slow rebound adjustment) built by Heasmans Steering. 8.0/6.25 kg/mm springs (will chuck in 14.0/14.0 springs to suit high aero/WTAC setup) ($8k when built a few years back) Serviced regularly by Heasmans Steering
Every suspension bush on the car has been replaced with urethane (including steering rack)
Adjustable front caster arms with notched upper arms (stops the top bush flogging out with more caster)
Whiteline sway bars both ends
Nismo strut brace on front
Nismo mechanical 2way rear diff/OE front
Second stage of power steer pump (ex-HICAS) now feeds power steer cooler between radiator and intercooler
OE G-sensor was calibrated to zero while on laser levelled corner scales
Corner scaled to 50.0% across diagonals with 90kg driver ballast (adding a 130kg navigator only moved diagonals 0.2%)
Turns in hard with very responsive steering
5000km old rebuilt RB26. 340kwatw on 20psi/98RON. Built/tuned for response/midrange
Haltech Platinum Pro (heaps of unused features like launch control, antilag, WOT shifting etc) tuned by Race Solutions. I’ve clocked just over 500km to a tank of 98, so it’s tuned for cruise, not just outright power
Haltech boost solenoid
Haltech two stage shift light on steering column
OE bottom end with ACL race series bearings
Crank modified with oil pump collar. All press plugs drilled out, pressure cleaned/acid dipped then grub screwed
Block bores/deck/tunnel specs confirmed well within OE tolerance so it only required acid dipping and honing
Rods and pistons acid dipped and crack tested. New moly rings gapped and fitted. Pistons/rods static balanced/weighed then entire rotating assembly dynamic balanced from balancer to clutch cover
9L large capacity sump (same depth as factory so it’s protected by crossmember in case of an offroad incident!) baffled, gated and sectioned with a 1” breather either side above the windage tray
Closed loop breathing system that vents sump to cam covers to ail/air separator before pre-turbo inlet. Oil front separator flows direct to sump (no emptying catch can every trackday…) Very efficient system, car doesn’t breathe much at all, possible overkill…
Head was stripped, acid dipped, all valve guides replaced, springs tested fine, OE valves inspected and refitted, intake ports knife edged, exhaust ports cleaned up a tad. Intake plenum/throttle plates/head match ported (not opened up) and head/exhaust manifolds also match ported
Cometic MLS head gasket with OE gasket kit throughout entire engine
Tomei PonCam Type-B’s (260/9.15mm in/ex) fitted and shimmed well within OE spec. Adjustable cam gears. Gates Racing timing belt
N1 water pump
Alloy radiator. Silicon hoses. Nismo thermostat
Tomei oil pump (that thing is a beast, just touch the throttle to get up on bypass pressure!)
Yellow Jacket coils
Nismo 550cc injectors
Garrett 2860-7 turbos on match ported OE manifolds with oil restrictors. OE dumps
Custom intakes (no MAF) leading to twin air filters inside carbon fibre air box (coz bitchez loooove carbon)
Modified twin turbo split pipe with separator which stops compressor surge between the -7s under light load
3” exhaust from turbos back with single JDM muffler (Jazma maybe?)
Uprated Jim Berry Full Monty. 1400kg Exedy pressure plate with 6 puck ceramic button sprung centre clutch
ARC curved oil cooler mounted behind grille running off a thermostatic TRUST sandwich plate
OE under tray replaced with flat alloy sheet back to crossmember
Since the engine rebuild, I haven’t had one problem (unheard of from an RB26. Buy into this iconic piece of history right here)
Currently has R34 GTR wheels fitted with tyres have a few mm on them till wear markers
Has wing, but not currently fitted
A little rust just behind right rear wheel
Couple of minor dents I CBF fixing up
This car was built to be a reliable track car with intention of tarmac rallying again.
It might not be the biggest power GTR out there, but is very capable package ready to lay down a fast time on a circuit or rally stage.
Throw in a cage, chuck on a vinyl wrap and grab some fresh rubber to go racing, or tint the windows and have a legit touge warrior (Hawkesbury hillclimb king, I’ve never had anyone stay with me for more than a few corners. All challengers accepted. Come at me bro. I have a medium quarter pounder meal for anyone faster…)
Half cage starts at $630, $2310 national level CAMS cage or $300 more for Tarmac Rally level CAMS cage
http://www.agi-precision.com.au/product-category/roll-cages/cams-roll-cages/bolt-in/nissan-roll-cages/skyline-r32-2dr/
Full car wraps start ~$2500+
So for $30k you’d have a reliable, competitive and log booked tarmac rally car with rego.
Car is $22k with freshly serviced Bilstein/MCA coilovers. I only negotiate face-to-face, so don’t contact me with offers to swap your 1000kw 12sec VL that your cousin built while in rehab…
Will come with the usual box of bits (spare fire extinguishers, safety triangle, some tools, removed interior bits etc)
I don’t like selling cool stuff, but it has to go as I have bigger things on my mind! (no, not a house, do you even know me?)
Call me, call me now... Mark 0417 049 016
Dyno pull and idle vid
https://www.youtube.com/watch?v=yZWgEWPTFqc
Car is corner scaled 15mm higher in rear ride height since pic
Rust on the trailing edge
In Targa Tassie guise
  • 2 months later...
  • 1 month later...
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
