OK for shits and giggles I enquired about this...
http://www.carsales.com.au/private/details/_/SSE-AD-3540905
Started talking to the guy on FB. Seems really friendly and helpful.
Assuming it would be a shitbox I started grilling him about how it's obviously been crashed etc.
He's tells me not in the time he's had the car (6yrs) and that he can't see signs of it having been hit... ok weird. "I tried to find the cleanest stock one I could".
Questioned the guards, bonnet, and front bar, boot.
He tells me, the bonnet came on the car, the guards he had made up (fibreglass but apparently really good quality, google tells me the nismo z tune guards are even fibre glass and only the actual z tune had CFRP guards).
The boot he had painted because he likes the look. Front bar and spoiler have been sold as he was not planning on selling the car. A top scret replica front diffuser is there as are the stock mirrors and guards.
He tells me the car also has a PFC (not listed on the ad), tuned for 240kw with stock turbos etc (1.2bar) as that's all he wanted.
Rims are also genuine.
I ask for some more interior photos - see gallery it's easily cleaner than the QLD car and not the existence of v-spec sensors on this apparently non v-spec car (i know you can add those sensors later indivudally and reconfigure the MFD or go the nismo MFD way)
He's getting me a VIN so I can do some digging and confirming K's etc.
He tells me underside is quite clean and nothing like the car i showed him and the only rust on the car is the two radiator tabs and that's why he showed me those.
I'm starting to think this could be a good cheap base to work off, spray the front bar, bonnet, boot, re-add spoiler (A mate of mine is an excellent spray painter with a business etc), get a rear diffuser and fit top secret replica front. -9s, injecotrs, pump, cams/gears and retune.
Am I crazy? OF course I would inspect for signs of crash damage, but if you could get this cheap and the k's and condition checked out...
http://imgur.com/a/FZIjK
Edited by ActionDan
Turbos seem to be about 1500-2k on the gtr group, injectors 500, fuel pump 200 or so and afms 4-500? 3k or so then a bit more if i wanted cams and gears, gears alone are bugger all.
Maybe 4k in parts there, rear diffuser is expensive 1500-1800 so i would just sit on that til i found one cheap.
The paint work would cost me the cost of the paint and some beers.
If you got the car for 40, spent 7 or so, that doesn't seem too bad?
The QLD car was going to be 46k with the spares so it would have come out cheaper but with all that rust to deal with and 55000 more ks (if the ACT car is genuine, wont surprise me if not).
Edited by ActionDan
8-10k if starting from scratch I think?
This has EBC, PFC and "full hks exhaust mines dump pipes" already.
I would be "guessing" to say that if it has dumps and an HKS exhaust it likely has fronts and cats done but fair point as that's extra cost, neither of which are that expensive.
Already has ATS clutch as per the ad,
Cam gears are cheap.
Tune is a valid point, I'm not sure if there's a 4wd dyno here so would likely get Chris at RacePace to tune it, when I spoke to him last he said tunes for adding mods like that aren't too bad, 4hrs etc, so less than 1k. I know some local tuners but the dyno access is the issue, one of the 4wd shops might have one but they get pissy about letting people use them.
I can do all the labour required (not painting but that's mates rates).
Edited by ActionDan
Dan that's a bit of a hidden gem imho.
Many won't have even considered because of the boot/bumper.
I personally would go stock guards, bumpers etc but that's me.
Leaves you a LOT of wiggle room to do things how you want. And you can play with cars again (aka hunt for parts etc)
DO IT
I thought that to switch R34 into RWD mod required bleeding the ATTESA system afterwards as it needs t be depressurized or something?
Didn't think it was as simple as dropping a fuse like the 32.
"I can do all the labour required".
I've fitted turbos before. Is it a shit job? Yes, but I'm capable of it. I've tuned (cheating as its only SAFC and SITC combo and some cam gears), aligned, and done all the upgrades on my track car plus all the service and repair of anything else I've had in the past including replacing a blown headgasket in the track car.
Swapping out a TT setup will be balls, but I'll get there when the time comes.
DO IT
I'm wondering this too. inspection and VIN review will tell me more so not getting my hopes up.
I like the Z tune guards, bonnet and bumper combo - once colour coded. Plus when I run off the track and smash up the front bar I won't cry as much knowing it was FRP.
I have the track car to play with so really I'm not looking to play with something else and don't get enough time as it is, but I'm not willing to drop 60-70 to get a fully done one how I want.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
