Hi, got some id1300s for my neo, but am having trouble getting them to fit. See pic (Plug base fouls on the manifold).
I was going to just grind a bit off the manifold but too much needs to be taken out.
Has anyone fit these type of injectors to a normal rb25 or rb25neo manifold.
On my old injectors the plug was more to the top.
They need spacers. These are pretty readily available. Those look like they are just the injector on its own. Pretty sure they need the smallest of the spacers, but top feed injectors in stock manifolds arent my forte
Scotty on here should be able to help you out. He will probably show up in this thread sooner or later
This is from a quick google search, bottom of the page. Click here
Edited by 89CAL
Cheers mate,
I have the height adapters for them to make them full length but they and most spacers go on the top of the injector?
Which doesn't help with the issue I'm having
Spoke to Scotty today, i may have to get him to make some spacers to go under the injector if i cant find anything else
Edited by Huzqld
Hmmmm I thought they made them for the bottom of the injector as well. But I may be wrong. They definently look shorter then my 1000cc's
I had a page with the pics of all the adapters etc attatched but cant find it. I may be talking complete rubbish though, Scott would know better then me
on a non neo you are required to fit an injector boss, which is just a metal spacer/o ring combo allowing the injector to be seated correctly.
Please don't go grinding anything.
That VPW fitting should work, I can get a hold of one and check it fits if you like, before you buy them, and work out what top spacer you will need too, as that needs to shortened by the same amount.
Thanks Scotty that would be great. Since I've organised the tuner for Friday it's all turned into a bit of a rush.. So I need to have them ordered early today.
If you've got one you can get hold of to check that would be awesome.
If I can't sort the top spacers out today I'll just space the rail up and sort that out after the tune
I just had the wholesaler flow test a 1650 shorty and you may have a problem with that idea. With that lower extension on the cone sprays out wide enough to hit the edge. It would have to be modified with a 45 degree chamfer, but this leaves the raw alloy exposed to the ethanol which is not a great long term option. It may get you by until you find a better solution though. Let me know if you want me to sort something out for you, I can probably make something up today and send the top and modified bottom extensions express.
Hey Scotty
I spoke to efi hardware, they have some adapters they Say won't affect the spray pattern, (they said the others do like you said)
and then I just run half height extensions on the top to make them full length
So hopefully that will work
*sorry short extensions on top
Edited by Huzqld
Hey Scotty
You don't want full height, you need 3/4 height for the neo.
Man, this is getting crazy, an adapter on each end, full length, the injectors will move around too much for my liking... You really don't want them popping out while driving, they need to be firm so make sure you keep the rail height down to minimum.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
