I'll be getting my car within the next few weeks. its got an rb24det with hks ecu, kkk k27 turbo, trust gate and manifold, rb26 style plenum, injectors, etc etc.
i have been thinking the k27 turbo will be too big, anyone had experiance with one of these on an rb20/25?
anyways i was thinking i'd down grade it and chuck on something abit more responsive. what sort of turbo choice would i be looking at if i still wanted to make approx. 240-250rwkw? can a 2530 make this sort of power? what about a 2835? t517z? etc.
https://www.sau.com.au/forums/topic/45981-turbo-options-for-240rwkw-rb24det/
i think the biggest concern will be finding somebody who can tune the HKS ecu (fcon?). You probably are best going for another ECU that can be tuned readily by a local workshop.
kkk turbos meant to be alright... quite popular in japan.. give it a try first!
2835 would be sweet, if you want to ditch the manifold you could go an internally gated GT-RS turbo. you will make easy 240rwkw with that. im looking into getting one of these for my internally stock RB20, and it makes over 220rwkw with the 2530. im hoping the GTRS will bring it up closer to 250rwkw.
the GTRS is still in HKS 25 series of turbos, is rated at 400ps like the 2835, but is said to respond more like a 2530. from all the articles i have been reading it is a very impressive package. only problem is they only just released it in T3 form (a bolt on for RB20/25 manifold) so it looks like the only way to get one is brand new... not many second hand bargains about.
as denzo would say dont be weak
yea mabye ur right, but i really hate laggy turbos :headspin:
but i'm definately going to change ecu, unless the HKS one runs awsome once i've put it all back on (i'll have to remove it all for a week or two for the rego inspection, so hopefully it doesnt loose its maps?)
what about getting another manifold and a second hand t28 gt-rs? probably budget 2.5k for a turbo swap as i'll sell the k27, manifold and gate.
so a new hks turbo is totally out of the question!
forum member Grepin has a 2835ProsS internal gate turbo on his RB25. It makes around 265rkwk at 1.2 bar of boost
I have been in his car, and it is very responsive and not much laggier than a stock turbo
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
