(Continuing from this thread http://www.sau.com.au/forums/topic/326464-best-place-to-try-racing-seats-in-melbourne/ )
Ok so I went and got a new seat for the R34 today, a Sparco Sprint V fixed back. Now I just have to get it mounted it in my R34 GTT Sedan :)
Here's what I've learned so far by having a look around (see pics below too):
  • The Sparco is both FIA and ADR approved
  • The OEM seat is secured by bolts not rivets so theoretically it could be replaced with another
  • The seat belt receptacle moves with the seat, which I'd love to retain with the new seat
  • The OEM seat bolt pattern is 325mm wide, 350mm deep
  • The Sparco bolt pattern is 345mm wide, 270mm deep, so it'll need offset plates at least
  • The bottom of the OEM is curiously shaped – the front is higher than the rear to clear the height/tilt control mechanism. I'm not sure if you can just drop in a flat bottomed seat but perhaps worth a go. With the rear of the seat at its highest I think a flat seat would clear the cross bars (see pic).
I didn't buy the Sparco slider yet as I'm keen to try mounting on OEM rails and slider if possible.
Has anyone mounted the Sparco or a similar fixed back seat on the OEM rails in a 4door GTT?
Is there any chance of retaining the OEM height/tilt controls without breaking the original seat? Would the new seat fit next to them? The controls go through the fabric but I'm sure the knobs come off somehow.
If OEM rails are not possible what's the recommendation?
I've read somewhere that Bride rails might work but I want to be 100% sure as this is a sedan and apparently the coupe floorpan is different. With the sedan the rear end of the LH rail bolts onto the transmission tunnel (side) whereas the front end and both ends of the RH rail bolt onto the floor.
Also what do you do with the seat belt receptacle (which I must retain for the street) on an aftermarket rail...?
Thanks heaps!!
Sparco bolt pattern:
OEM seat bolt pattern:
Seat adjustment mechanism:
Seat adjustment knobs:
Sparco Sprint V:
I'm planning on running normal 3-point belt on the street and a 4-point harness on the track, a bit like this (notice how the seatbelt receptacle is slotted through the side of the seat):
On the track I'm planning on running the harness to the rear seat belt points as a harness bar is not an option in this car:
One more photo of the R34 GTT sedan driver's side rails, see how the LH rear bolts to the side not the floor:
Edited by V28VX37
Ok I pulled out the OEM seat tonight. I'm 99% confident that there's no way to reuse the stock rails, at least not without binning the rest of the seat, which I don't want to do.
The under seat bolts that I measured previously are just for the seat part, the reclining seat back is another separate piece. Also the seat part mounts onto separate 'rotating' L brackets that sit too close together across for the new seat to fit in between. The new seat is about 410mm wide at the bottom.
Any recommendations for aftermarket rails for the sedan? I've seen Bride and Powerails, leaning towards Bride but I want to confirm that they suit the car and the seat 100%, with no mucking around.
Underside of the seat
Space between rails. You can see how the seat brackets and bolts sit a lot further in still.
Seatback adjustments
Seat rails mounting points
Seat rails mounting points, see the curious hump up front and the holes for the twin 'alignment pins' next to the front left leg:
I've tracked down the following Bride rail on sale:
BRIDE bottom mount seat rail type-RO drivers R/H side for NISSAN R34 GTT, W405mm x D260mm/235mm bolt holes
Details off the sticker: Bride Super Seat - Model R34(RWD) - Type RH - Code N105 - Parts list B
> Can anyone confirm if this rail suits an R34 GTT sedan?
I've found two older SAU for sale ads for 4door Bride rails and they had the following details on the (older style) sticker:
Bride - Model R34 - Type RH (T) - Code N105SO - Parts list SN*1
I can't find a clear answer if N105 and N105SO are for coupe and sedan, or whether the N105 is just a newer version of N105SO?!
Here's the approximate bolt pattern measurements off the floor pan that I need:
Ok I've ordered this rail, fingers crossed: Bride Super Seat - Model R34(RWD) - Type RH - Code N105 - Parts list B
Next problem: The eyelet bolts supplied with the Sparco harness are M11x1.25 and fit nicely at the rear seatbelt mounts, however the seat rail bolts are M10x1.25.
Any suggestions on where to get high tensile (grade 10.9 Metric) eyelet bolts in M10x1.25 in Melbourne or online??
I got the Bride N105 and I can confirm that it suits an R34 GTT (RWD) sedan. It's good quality, just needs offset plates to suit the Sparco seat.
In hindsight a side mount rail might be better to help go a little lower and allow for tilt adjustment too.
As someone with a sedan, looking for a decent seat in the future.... please keep posting cause this is super useful :P
Haha thanks Greg, I knew someone must be reading!
Let me know if you ever want to check the seat out in car, it's quite different to just sitting in one in the shop, let alone browsing eBay for cool Bride copies... :)
Some initial impressions of the Sparco Sprint V in the R34 GTT - it's certainly night and day between that and the OEM seat:
Pros:
  • Great fit around the hips and shoulders
  • Lateral support is brilliant
  • Standard seatbelt doesn't foul the seat shoulder
  • Solid fitment on the Bride rail with custom offset plates
  • Excellent restraint in track setup with the 4-point harness
Cons:
  • The front thigh bolster is pretty high, which means I need to sit pretty close to the steering wheel to reach the pedals well. Side mounting would help as it would allow tilting the seat forward a little.
  • It could be a touch lower, currently it's very similar or marginally higher than the OEM seat - which goes really low for a stock one! Again going side mount would probably allow another 5-10mm drop.
  • Getting in and out of the car is like gymnastics but I'm getting used to it :) A bit hard in tight car parks though
So the main potential improvement is moving from bottom mount to side mount for more adjustability.
I'm also looking at getting the lumbar support pads that come standard with the Sparco Pro 2000.
I'll try to report back after some longer term use.
Thanks 75coupe.
Just to add to this thread, this is a great introduction to race seat fitment from OG Industries:
http://www.ogracing.com/blog/2013/06/race-seat-fitment-introduction/
http://www.ogracing.com/blog/2013/06/race-seat-fitment-sparco-evo-series-and-pro-2000/
This picture shows the difference between what you use to bottom mount and side mount a seat. The red arrows point to what the item above is attached to.
Ok I'm having trouble finding high tensile harness eye bolts in M10, any suggestions? I only need two to replace the two seat rail rear bolts with.
I realise that this is not going to be an FIA spec solution but I'm not keen on drilling holes through the chassis and installing M11 mounting plates for a couple of track days a year...
These are rare as hen's teeth. I've ordered a pair from Japan, hopefully getting them soon...
Hey here's one for the interior specialists. For the shoulder straps I've mounted the Sparco harness eye bolts at the rear seatbelt mounts. The left hand side can be accessed (just) via the seat belt slot/cutout in the seat, however the right one can't.
I'm not too keen to have to pull out the rear seat bottom part every time when wanting to use the harness so I'm planning on cutting a small hole through the seat foam, see pic below.
Any thoughts on how to tie down the upholstery around the new hole to avoid it tearing??
I had another another look at this today, it's a bit trickier than I thought.
I cut a hole into the seat foam - didn't cut the fabric just yet - to get a feel for how it might work, see below for photos.
The harness eye bolt is located in a spot that covered by a thick piece of seat foam so it sits deep, about 10 cm.
This means that I won't be able to get the Sparco hook directly onto the eye. Does anyone know if there's an extension clip/rod (?) and where I might be able to find one? I mocked up how this might sit below.
Also I'm still after some ideas on how to hook in/secure and protect the fabric around a 25mm hole once I cut it.
Photos
Sparco harness eye bolt and hook
Extension rod mock up
Seat foam pass-through hole
Seat fabric that needs to be cut
Lastly here's a 'side belt extension' I found online that could theoretically work:
or this 6" bend angle bracket (I suppose one could make this too)
Edited by V28VX37
I've ordered one of these, should be pretty easy to run through the seat trim and then hook onto that, fingers crossed. Also can be folded away when not in use.
  • 3 weeks later...
Well I can now run a four point harness without taking out the rear seat or adding any holes, yay!
I ended up running the seat belt extender around the rear edge of the seat bottom (rather than through it), works well. See pics below.
I've also got the standard Sparco harness eyelet bolt under there (7/16" UNF) so in case someone doesn't like the setup in scrutineering I can just hook directly onto that instead.
The D shackle is a 1 tonne item from Bunnings.
Just in case anyone else is looking for the eyelet bolts that go in the seat rails they are M10x1.25.
Very hard to find, I spotted them via this NASIOC thread (thanks!): http://forums.nasioc.com/forums/showthread.php?t=2696767
They're offered by Moto-Rage in Japan: http://www.moto-rage.co.jp/product/partslist/hanyo/other/index.php
I tried contacting them directly but got no response, luckily Jesse Streeter sorted it all out for me, great service as always. http://jessestreeter.com/
I'd say the harness makes almost more of a difference than the seat, it's rad! Not a straightforward install but well worth the trouble.
Photos
Two M10x1.25 eyelet bolts, Sparco 7/16" UNF in the middle
M10x1.25 eyelet bolts installed
Seat belt extender installed under the Sparco eyelet bolt
Seat belt extender without harness
Four point harness installed
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
