So you recomend this to anyone who wants a powerfull "no lag" gtr ?
no,
i would recommend this to someone who wants to run a single with similar response to low mount twins, who wants more power than is availble with low mounts.
and b4 someone says it, i know this power is availble with low mounts, but would need minimum 2540s or t518z and both would spool similar to this,probably worse.
  • Replies 141
Woohoo! I guessed single turbo, but HKS T04, not Garrett T04 ;)
You guessed 3 possible turbos, one set of which was twin low mounts:
"A bit hard to say with no peak power figure, but I have my money on a single turbo.
Perhaps a Trust T67 or HKS T04/GT3040....
Hmmm.... or could they be elusive AX53B60 turbos?"
How that makes you greater than everyone else is interesting.
edit: fcuk it... I couldn't be fcuked.
First person to make my ignore list on SAU. Congratulations.
Wow... 19" wheels and dials up 417kw ;) Impressive :D
4th Gear Speeds:
2000 - 59km/h
2500 - 74 km/h
3000 - 89 km/h
3500 - 104 km/h
4000 - 119 km/h
4500 - 134 km/h
5000 - 148 km/h
5500 - 163 km/h
6000 - 178 km/h
6500 - 193 km/h
7000 - 208 km/h
7500 - 223 km/h
8000 - 238 km/h
8500 - 252 km/h
I'll put them on the graph now :)
Uneven spacing of RPM... Where have I gone wrong? ;)
for comparison sake, here is a dyno sheet from a few weeks ago , same car but with hks t51spl(non bb).
only other changes, now has a slightly more restrictive exhaust(other one was too bloody loud ) now also has the wastegate plumbed in.
both dynos were done at around 23psi.
merli, maybe u could apply the speeds to this one.
just havin a lend of ya s/k.
so what do u think, give me your impressions, bearing in mind, the aim was to get around 400kw.
Its a dog ;) ... i thought with those sorts of number the owner may have put an RB20 from a GTS4 in it...those numbers seem about right for an RB20 :rofl:
What sort of compression ratio is the car running, and what level of boost to make that power...its always frightening to see a convex power curve like that, typically means good power delivery
23psi,
I feel light headed, i need to sit down :D
It makes that sort of power with that sort of response, at a little over 1.5bar. Im no expert but that is brilliant. Do you happen to know what cams and compression ratio the car is running... std stroke and no special fuel?
I notice that most dyno pritnouts with big numbers are usually concave curves, and doing the math, you get more urge if you reach the same number with a convex curve....
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
