Hi again y'all
Has anyone ever seen the Vic based white 34gtr with the plates K1NGTR?
Once again, I am currently speaking with the owner regarding the sale of the car. Below is the link:
http://www.gumtree.com.au/s-ad/melbourne-cbd/cars-vans-utes/nissan-skyline-gtr-34-vspec-/1090378983
Apparently, the original cluster was replaced with the nismo cluster (owner bought) with 25870 on the clock (kms clearly seen on pic). However the original cluster had 78000km. The owner believes that the car has done around 100000km in total to date.
The car appears to be in pristine condition according to pictures with minor mods...... which is ideal.
In addition, papers will be provided to substantiate the cars authenticity. Just waiting for a copy and will go from there.
Your thoughts on this is greatly appreciated.
Thanks
Pay for Japanese paperwork check from businesses like Japanese Odometer Check
https://www.facebook.com/Japanese.Odometercheck
This will provide u with a auction sheet and de-registration certificate. And of course usual pre- purchase checks.
On the other hand, sesh have prices for bnr34's have soared!!
correction guys, the car has done around 80k on the clock.
The original cluster had 79,878km
The new nismo cluster was put in @ 24,051km. Owner advised that he uses the car for show and has added an 1000km since the day of purchase and new nismo cluster put in.
The car itself is pretty much stock apart from the exhaust and the apexi pods.
I'll definitely pay joc to confirm car status before i go any further with it.
Should i even consider buying this car with a changed cluster?
What are cons if i was to buy it? Will it be a headache if i was to sell the car in the future?
Edited by JRelle
Sure why not? JOC will will confirm kms.
I actually like the nismo white dials
I'm just assuming you're after a near-stock example (not sure if you've mentionned in this thread or the other one what you'll be using it for)
$59k seems a little high but around the $55k mark would be these days prices for such an example provided everything checks out.
maybe a year or two ago it would have been more closer to $50k for a stockish one
Yes, i am looking for a near stock 34. Im not much of a modifier, im more of a cruiser.
Just on the JOC website and it appears that they only report on kms? how about auction sheet?
Km reading means jack all. You could find one with 50,000km and be a total piece of shit and then you could find one with 120,000km and be extremely well maintained.
Any GTR will require money to keep up the maintenance, insurance & registration, modifications etc.
Check out the history by paying the $80 or whatever it is. Then get it inspected by a workshop and a report on the condition or go yourself at the inspection time and have a look at the car. From there you can make your decision before you decide to hand over around $60k.
This car was advertised for 38k earlier this year. It is a rust bucket. i would advise you to not get it as I have looked at this car myself. i found a lot of surface rust underneath and rust in the engine bay where the intercooler is.
http://www.sau.com.au/forums/topic/455501-1999-r34-gtr-v-spec-vic/
this is the same car.
  • Like 1
Much appreciated mate. Ive moved on from this one.
It's already begun
At this rate, I can only imagine the rampant profiteering that will be happening to these cars 8/9 years from now
with that guy trying to profit 10k+ for what he purchased it for worst thing is he only purchased it this year.
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
