Drivers window has been playing up in that auto wind up would get to 2/3rds up, then reverse back down. Holding the button would make it power though with a tiny pause. Now the window is stuck at 1/3rd up and wont move in either direction. I guess the first step is to check all the fuses in the drivers side footwell - unless someone knows the right one. Anything else i should look at?
Yep, and the cover inside the door latch, you need to unclip the two plastic clips near the hinge, pull towards yourself, then slide the trim upwards.
See if there is a G35 clip on youtube, that will help.
The 2/3rd up issue was a seperate issue for you. That is caused by it losing its programming for height. Once you remove the door trim if I remember rightly there was a black sticker around the centre of where the motor sits. If you remove that sticker it gives access to a button that allows you to program the height the motor goes up to. I can't remember the exact process used to program it. But I'm sure you will be able to work it out.
  • Like 1
. Remove the Door Panel
2. With the door open, lift UP and HOLD the Window Switch until the Window is fully closed.
* Do not use the Window auto-closing function
* Do not release the Switch before the Window is fully closed
3. Get inside the vehicle and close the door.
* You need to close the door so the Door Switch is fully depressed
4. Press and HOLD the Window Regulator Motor Reset Switch. While holding the Reset Switch, press DOWN and HOLD the Window Switch until the Window is fully opened.
Do not use the Window auto-opening function
* Do not release the Switch before the Window is fully opened
5. Release the Reset Switch. Then, lift UP and HOLD the Window Switch until the Window is fully closed.
6. Open the Door to release the Door Switch. The Window Glass should partially move down.
7. Re-install the Door Panel.
  • Like 3
This needs to be added to the m35 über thread
  • Like 2
My drivers window gets stuck at 3/4 also but makes a slipping teeth sound like the worm drive is shot. I check out my bushes and as Scotty mentioned they were also very worn. I bent them out so they contacted better and it fixed half the issue(new bushes would be better)...still need a new system I think.
I have one new aftermarket window motor here, these are probably your best choice as most of the drivers window motors are flogged by this stage.
I have done the same a few times, cleaning the commutator and bending the brushes in will keep it going a few more weeks/months.
Everything's back together with a new motor from Scotty. However, when i open the door for step 6 of the reset procedure, there's no window movement so i'm guessing it hasn't taken.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
