Hi all,
Wanted to get people's opinion on how to best/easiest way to do this.
Im using an eboost which is mounted on the turbo side of the engine.
The lines off the solenoid go under the inlet manifold, seemingly into the abyss.
Am i better off using some long nose pliers and reaching under the manifold yo undo the hoses from there or should i remove the whole line around the engine?
Are there any hardline mounting tabs under the manifold?
Iv looked into the workshop manual,the lines dont look like they tee off into the manifold...or am i wrong?
Thanks
You have to run a line from the plenum to the steel hose that runs around the back of engine, I can't remember off the top of my head if it is top or middle hose
If you pull both off the get off one of the wastegate lines at the actuator and get someone to blow into it then feel for which one has air coming out of it and connect to that one
I put my solenoids under the brake boost for less heat and less visibility then run hose from plenum to solenoid then from solenoid to steel line
There is one tab on intake side that has bolt that goes through it then through head and bolts into block, there are three lines ( 2 x air and 1 x water ) that are connected to each other
I will also suggest getting something better then an Eboost
thanks for the response. i ended up having the battery and cooler pipe off the car to create some room.
you can juuuuuuuust see where the hoses connect to the hard lines. managed to get some pliers in there to shift the hose clamp, then i just yanked off the hose.
plugged them up by looping them with some random vac hose i had. havent started the car yet as im doing a few other things before i put it all back together.
i bought the car with an eboost lol, its primitive but it works fine! when i get a haltech ill get a boost control kit too.. im due time.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
