i got my nos kit in today and i did a compression test to be safe,
Test results
piston 1) 135
2) 145
3) 140
4) 130
5) 135
6) 135
Does anyone have the standard compresion test of a rb26 motor. just wanna see if my compression is low.
https://www.sau.com.au/forums/topic/46039-compression-test-results/
Compression test is all about consistency, the absolute number is not comparable. Cranking speed, engine temp, ambient temp, battery condition all make a difference. That's why a leak down test is superior, it removes most of the variables.
I have got around 135-140psi across the range on an rb25det engine.. which was otherwise fine.. factory is meant to be 172psi or thereabouts. I think it can just be the guage - mine was like $70 :rofl: i think its always shown pretty low on the few engines I've tested it on.
As previously posted, personally I wouldn't stress over the absolute number, it's the comparison that's important. The manufacturer quoted compression test relies on the engine being up to operating temperature. Did you do it when the engine was hot? Not reasonably warm, or even worse, stone cold so you didn't burn your hands when removing the spark plugs. It has to be at operating temperature, that's 80c or above or halfway on your std temp gauge.
Secondly it is done with zero resistance, no dragging clutch, no tight fan belt, no air con compressor etc etc. No electrical load, this means you can't have the radio on while doing the test. Thirdly it is done with a brand new battery and starter motor. All this means a faster rotation speed during the compression test.
I have personally never achieved factory compression in any car I have tested. So unless you unbelievably unlucky and all cylinders have worn exactly the same amount, the very close results for all 6 should give you confidence. :rofl:
15 PSI difference from Piston 2 - 4 is a little worrying.
I'll bet he started at cylinder #1 and the engine cooled down by the time he got to #4. :headspin:
Or the battery ran down a bit from the cranking :D
actually the car was sitting on a hoist for 2 days, and the second day the car wasnt started so it was stone cold while doing the compression test, also battery was a little flat.
so hopefully the compression test results were ok.
I did a compression test the other week on my car - 125 PSI exactly accross all cylinders (That's after a rebuild and run it)
Seems low - but it still pulls like a $50 whore - so all good
Ummm - that's when the AFM and ECU are working :)
Mine has thicker head gasket and cams - so that't prolly why
Any good place can do a leak down test. I think UAS can as I asked John about this...
It involves taking a plug out - shoving compressed air into the cylinder and leaving it there for a while whilst measuring any pressure drop - if the pressure doesn't drop - all good - if it does drop , there may be a problem.
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
