Let's get together and run amok in Shepparton for the weekend as the last motorsport event of 2015 takes place.
Where: Courtyard Motor Inn
Address: 58-60 Wyndham St, Shepparton
When: Fri 11th & Sat 12th December
I've reserved the entire hotel, so you need to let me know which room you would like booked and I will put your name to it.
Dinner: TBA (group event out somewhere)
Rooms left:-
1 x Family (Queen & Bunks) - $130
1 x Deluxe Spa Room (Queen & Single) - $115
1 x Disabled Standard (Queen) - $115
2 x Standard (Queen & Single) - $115
3 x Deluxe Spa (Queen) - $100
3 x Standard (Queen) - $100
Entries coming soon................ :)
Rooms Booked:-
BOTH NIGHTS
Leon (Family Room)
Bec (Standard (Queen) - $100)
Campbell (Executive w/ Corner Spa (Queen) - $145)
Odie (Standard (Queen) - $100)
Wayne (Standard Queen - $100)
Jett (Queen + single - $115)
Jake (Deluxe Spa Queen - $100)
Myles (Deluxe Spa Queen - $100)
Russell ( 2 b/room family (R1 Queen, R2 Single & Bunks) - $155
Mark Ryan & Dano Standard (Queen & Single) - $115
Jeremey Barrell (Deluxe Spa Queen - $100)
Ryan (Standard (Queen) - $100)
FRI ONLY:-
Anna (Deluxe Spa Queen - $100)
SAT ONLY:-
Aaron Tan Standard (Queen & Single) - $115
Hi Guys,
Thanks to the above and others who have messaged me re accommodation.
I've only been home from overseas for a few days and the list is now updated.
Cheers for your patience.
NOW - get your entries in ASAP people :)
Bec
  • Like 2
Hi Guys - please note the list above is now current.
As there are so many rooms not taken, the hotel have taken control over the remaining rooms as of right now. They will be taking bookings from other groups, so I suggest you move quickly if you want a room.
If you need to make a booking, or if you need to alter an existing booking, you will need to contact the hotel directly:-
Brendan Magee,
Courtyard Motor Inn,
58-60 Wyndham St,
Shepparton 3630.
P: 03 5831 2355
F: 03 5831 2748
[email protected]
www.courtyardmotorinn.com.au
Thanks and see you all up there :)
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
