Hi all i have a R33 gtst auto at the moment i have about 170 rwkw the mods are safc2, GFB Stealth blow off value, Blitz sbc boost controler, 3inch exaust & a blitz front mount intercooler it is running 11 psi at the moment and i am wanting about 200 rwkw so if some one could suggest some mods that would get me around the 200 rkwk area. I dont realy wanna spend thousands either but open to sugestions
Would cam gears do the job or would i be looking at a new turbo then if i buy a new turbo would i have to get bigger injectors and fuel pump or is there something else i could do well thanks for ya help
https://www.sau.com.au/forums/topic/46067-need-help-reaching-200rwkw/
  • Replies 69
bigger intake and outlet for the turbo
eg dump pipe 3' and metal pipe replacement(thats just my suggestion as mine is starting to collapse), stage 2 shift clutch so the trans can handle the power ya putting through
GTR pump and computer you should easily be there if not it'll likely be arounf the 220rwkw
Hi all thanks for ya help i might try getting a dump pipe from some where and trying the fuel pump. i have heard i might be able to get a uni chip installed but then i would have to take my blitz boost controler off has anyone else have a uni chip are these good ?
fuel pump, adjustable fuel regulator, dump pipe, hi-flow cat, bump boost up to 12-14psi (ran my stock turbo on 1bar for round 2 years an still was in good condition when removed for the upgrade), pod filter. all that should get you to 200kW+
as far as unichip, i think its only an option for R32's, havent heard much about them.
to be honest, havent really researched into it as far as the AUTO bit goes being I have a manual, surely theres a powerFC with the auto option, or a Microtech or the new Wolf 3D?
there are plenty of high powered R33 auto's out there, an I'm sure they cant be running on a stock computer. Send all the ECU manufacturers an email and find out, thats what I'd do.
or start a new thread on R33 AUTO AFTERMARKET ECU'S?
What ECU do you suggest, keeping in mind that it's an auto?
Nope manual only for Skylines
or a Microtech
Nope
or the new Wolf 3D
Close, but still has gearshift quality problems and gearbox durability is questionable.
Waste of time, they tell you they will, and then when you find they don't, try getting your money back?
The only true HIGH powered ones I have seen have "non electronic" autos (Raceglides etc).
Yep that's been done a heap of times, no one has a GOOD ecu yet. There are a few that are close, but no cigar.
Then why did you tell MR R33 GTST to get an ECU, when there isn't one? He spelled it out in the first sentence of his opening post
Sorry, that last one was a bit harsh :P
Next time your down in Adelaide give me a PM. My auto works fine and has been tuned at Tillbroks and MorPower. Admittedly I am not running huge power yet (only 200rwkw) but I havnt taken the plunge on a new turbo yet.
Are you still running the standard ecu to control the ignition for the gearchanges?
We are racing at Malala in late August, maybe try it then?
no- I just pulled the standard ecu and replaced it with the PFC - no problems.
I have been told by others many times that this wont work because a friend of a friend knows someone that heard that this wont work, but my argument is "look at mine, no problems and it all works well - including the gear changes.
I have a wolf3d in my auto skyline and its getting dyno tuned tomorrow........the gear changes arent that bad but it does hold the gears a bit longer and 1-2 is a little more jerky. I have read on this forum that if i run 2 wires from the wolf3d loom to the auto ecu and tap into the TPS and tacho wires it will shift fine.
I have been searching for a wiring diagram for the auto r33 ecu but i cant find one, so i dont know which wires to tap into......if anyone has the diagram ill be able to try this and know for sure.
But.........
Since it is designed for a manual, the Power FC has no provision for retarding the ignition on gearchanges. In fact it doesn't even know that there are gear changes, since it has no programming to talk/listen to the auto ecu. Unless you lift your foot, this means that you get full power (torque) during the gearchange. This is not good for smooth changes and it is very harsh on the auto. The most wear occurs on the slippage during gearchanges, having full power then is not so good. ;)
This is not "friend of a friend" stuff, plus I have tried a number of times to get it to work with quite a few ECU's. Always the same problem, jerky shifts and flaring on the change. We saw a 40 degree increase in gearbox oil temp in a 20 minute drive as a result. Plus it get worse very quickly, over 200 rwkw and I reckon I could kill a gearbox in a week. :wassup:
It's not like you plug the PFC in and the engine won't run, that's simply not the case. It runs perfectly fine and can be tuned just the same as a manual. It is the interface to the auto that is the problem.
Maybe it's time for some more research, I will be talking to Tillbrooks tomorrow, I might as well ask some deep and meaningful questions. :rofl:
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
