Hi all,
I have the following items for sale:
2 x HKS GT-RS Turbochargers
Price: $1600.00
Reason for sale: replaced with Garrett -9s.
Dual Blitz Super Sound Blow off Valves
Price: $150.00
Reason for sale: reinstated OEM BoV setup.
GReddy PRofec B-spec II EBC (NOTE: in-car controller only does NOT include wiring harnesses or solenoid)
Price $50.00
Reason for sale: not required for my setup.
All were removed from an R32 GT-R making 305KW. I don't have much detail on these items as I bought the car and it went straight to the workshop to have an engine transplant and the above work performed. The previous owner advised that one of the GT-RS turbos had been rebuilt but I don't have any receipts to confirm this.
Pick up in Melbourne or will post at buyers expense.
Please contact via PM for further details.
Thanks
Bump.....
Also have the following items for sale and will have photos, description and prices up for them soon:
R32 GT-R OEM wheels x 4
R32 GT-R OEM front indicators
R32 GT-R OEM front brake calipers
Suspension taken from an R32 GT-R
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
