Bodyform Aero Top Secret Style diffuser with carbon finished lip - never fitted. - $700
Factory R34 Guards including skirt, no riser or badges (KR4) - $700
Factory R34 Mirrors, plug removed to fit aftermarket mirrors - $100
Rays Red Dura Nuts with lock nut tool, have faded a bit and are marked from being used. No pics at present but can get some. $100 (will inc postage).
ARC Titanium Gearknob - $150 (will inc postage)
Will also have a catch can for sale shortly.
Can get more pics, happy to help arrange freight (can get decent prices).
Car shown has lip fitted to show you what it looks like on.
I'm also after a Justjap over the cam covers style catch can, a double din head unit to fit a 34, rear speaker covers, and an R34 rear diffuser and would be willing to work something out.
20151101_200308.jpg20151101_200332.jpg20151101_200519.jpg20151101_200657.jpg20151101_200731.jpg12077158_1808719322688275_388703016_n.jpgpost-102975-0-18848800-1392010286.jpg
Guards and diffuser sold pending payment.
I am also on the lookout for a stock R34 Airbox and Nismo intake. I have an ARC box to part with and do a swap.
attachicon.gifETang-0153_zpse52b8188.jpgattachicon.gifcp4798999826031584683 - Copy.jpg
Would you swap stock air box and snorkel for the arc?
Mmm would like a Nismo snorkel and value wise I think the arc is worth more so without the snorkel I think there'd have to be cash my way.
Though I need to confirm what the arc is worth.
Interested, will check what the arc is worth tomorrow.
Can you confirm what filter you have and also a ball park what the airbox and snorkel is worth to you.
Bump, taking offers on the wheel nuts/ mirrors/ arc shift knob, just looking to clear them out.
Will have ARC box for sale soon too, also likely to have some Tomei manifolds and dumps, stock manifolds and sheilds, an after market front pipe, and maybe some water/oil lines.
Happy to take $50 posted for a set of wheel nuts, $100 for the gearknob,
Also have this oil air separator which is basically brand new.
post-23873-0-05568600-1449096603_thumb.jpgpost-23873-0-68748600-1449096604_thumb.jpgpost-23873-0-03121300-1449096607_thumb.jpg
  • 1 month later...
  • 2 months later...
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
