Awesome day, great cruise and had fun taking shots of all your cars.
Here's 2 for now, got a whole album to go through in the next couple of days.
Link will be up on my Facebook page: http://facebook.com/atjldesign. Cheers!
Edited by jase.
  • Like 5
Matt, that photo of the two N1s from the rear left is amazing! Don't think I'll ever get sick of the R32s body lines.
Thanks Mark! Definitely a classic in terms of proportions and styling. You can't mistake it for anything else!
I think it was your VS2 that I spotted as well? It was very nice!
John Keogh Has posted up all the shots he has of the Skylines.
http://www.keoghsvision.com.au/sau-on-the-putty-13122015-1.html
They all look pretty good. Should have a shot of everyone, if not he has a fair few that are a tad blurry ( like mine ) that you have to message him for.
Edited by CaptainFresh
  • Like 1
John said he has two shots of my R32 which I'll look at later tonight.
* Usually he picks a really good backdrop.
* The only criticism is that doesn't pan the shots to enable the concept of velocity. His shutter speed is high and thus, the rims look stationary too.
* But in spite of that, they can be great keepsakes.
  • Like 1
Thanks James! Couldn't miss those guys hanging out at the corner there, so was wondering when those pics would turn up.
Fantastic work from John K! :D
Yeah I agree with this assessment. But it seems that he, as a photog, has his method, has it down pat and doesn't try and mess with it (well, during a shoot, anyway). So I understand that.
I noticed he started doing the multi-car panoramas, which are pretty interesting and would look great in large format.
  • Like 3
Unfortunately or rather Fortunate in this
My car looks like it is actually moving quickly, Mainly due to the fact of the Shocking Body Roll haha
He didn't put mine on his website as it's not a clear shot etc.
  • Like 1
Gangsta lean, lol
  • Like 2
I went Through Galston Gorge on the way there ( i live near Newcastle ) My go pro decided to work in the Gorge, You can hear the front Tyres Scrubbing on the inner guards in the video
( even though the Microphone was behind my rear number plate )
I think a suspension upgrade is in order :woot:
Emailed John about my photo's and my mates in the Ralliart .
he has 3 photos of each, and $5 per photo. All look awesome, Great value in my opinion.
  • Like 2
Yes the white VS2 is mine, thanks! I love the car and it was great to have it out on such a good run.
  • Like 3
Ok guys. So, photos can be found on my Facebook page here: https://www.facebook.com/godspeedphoto/ - please share and tag!
Now for some photos at the meetup at McGraths Hill McDonald's:
Cheeky drive-by
Vertex
At the meetup
Loved this classic
Itasha
Three 33s
Michael's BCNR33
Kosta's BNR32
Hardware
Brake
Those N1 twins again
  • Like 2
At the Truck Stop / half-way point:
The road ahead...
REAP3R - an amazing vehicle
SAU
Nestled.
Spotted
Meeting Ned Kelly.
Stag
II F4T
Evangelion
All-sorts.
LMGT1
Weapon.
By the numbers.
At the back end.
Tucked away.
Track regular.
R32 Lineup.
Social.
Super clean V.spec II
CE28s.
On point.
Guns and Ganadors.
Happy trio.
That doesn't look like yours
Mates
  • Like 4
And finally, refuelling time (again?) for the E85 boys! :P
I love this shot!Right place - right time!
And thank you Brett for briefing us at lunch about your car and HKS V-Cam!
  • Like 3
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
