Eisen Posted November 23, 2015 Share Posted November 23, 2015 (edited) Hello everyone, I'm swapping a rb26dett engine in my r34gtt and need help with the wiring. Has someone done this before me or does someone know wich wires I musst put together? My plan is to run the original neo loom for all bodythinks line lights abs wiper and so on, and the rb26 loom only for the engine. I will be thankfull for every help Edited November 23, 2015 by Eisen Link to comment https://www.sau.com.au/forums/topic/461232-r34-gtt-rb26-swap-wiring-help/ Share on other sites More sharing options...
6BANGER Posted May 27, 2017 Share Posted May 27, 2017 Hey mate did you end up doing the engine swap? I have a R34 GTR RB26 in my GTT and currently running the RB26 engine loom and GTT body loom just like you mentioned. Engine starts and drives but I have the ABS light on due to the left wheel speed sensor. Link to comment https://www.sau.com.au/forums/topic/461232-r34-gtt-rb26-swap-wiring-help/#findComment-7831669 Share on other sites More sharing options...
iruvyouskyrine Posted May 28, 2017 Share Posted May 28, 2017 Is the left wheel speed sensor connected? Link to comment https://www.sau.com.au/forums/topic/461232-r34-gtt-rb26-swap-wiring-help/#findComment-7831787 Share on other sites More sharing options...
6BANGER Posted June 11, 2017 Share Posted June 11, 2017 (edited) Yes, the left wheel speed sensor is connected in the engine bay. However, the wiring loom near the ECU uses different connectors between the GTR and GTT. I was hoping someone can shed some light into how the GTT body loom can be connected to the GTR ECU. Edited June 11, 2017 by 6BANGER Link to comment https://www.sau.com.au/forums/topic/461232-r34-gtt-rb26-swap-wiring-help/#findComment-7834413 Share on other sites More sharing options...
DanielH Posted June 18, 2017 Share Posted June 18, 2017 I swapped an r32 rb26 into my na r34 and just used the neo engine wiring loom with minor changes like tps and cas plugs. Much easier to just use the rb25 loom with a tuneable ecu. Link to comment https://www.sau.com.au/forums/topic/461232-r34-gtt-rb26-swap-wiring-help/#findComment-7835633 Share on other sites More sharing options...
