Argo rods cp pistons Rams head hyper tune plenum nitrous kit nitto oil pump 700 cc injectors shit tank 2 x 044 pumps surge tank twin high mount apexi rhx6 turbos rated at 1000 hp trust twin entry inter cooler all plumbing done by hyper tune bride seat immaculate trim and carpet no bubbkes in dash or door trims NOS GTR Steering wheel triple plate os geken clutch indy blue coils the cams Are hks I think there 272,s short shifter greedy boost controller custom exhaust magnaflow 100cell cat and rear muffler external waist gate blow off valve tomei fuel rail haltek computer platinum pro Full NISMO kit 260km dash 27000kms engine has done 2000ks built by CV performance R34 GTR wheels 32GZLR plates
$35000
Car is in sydney 0414454347 call Peter
Edited by suxgas
https://www.sau.com.au/forums/topic/461475-1991-r32-gtr/
  • 3 weeks later...
So, I know this may be quite a long shot. Would you be willing to export to the US? I currently have a 90 GTR, and I can store a 91 for free as I'm a dual citizen of US and Canada. I'd obviously pay all the associated costs of shipping,export,import,etc.. it is a question of if you'd be willing to help in the process as far as assisting in the arrangement of shipping. This car is super attractive considering it costs $25,000USD to get a rusted bone stock R32 WITH 60K+ Miles. So if you would be willing to help assist in arranging shipping the car from Aus to Canada, I'd be interested. PM me if you'd like to discuss further, if not I totally understand.
  • Like 2
https://www.sau.com.au/forums/topic/461475-1991-r32-gtr/#findComment-7660148
ask him nicely he might even load it on the ship personally ;)
https://www.sau.com.au/forums/topic/461475-1991-r32-gtr/#findComment-7660351
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
