On ‎3‎/‎12‎/‎2016 at 11:57 AM, dezz said:
Wasn't it button's call to walk? Or was he talking shit in the interview I saw where he said its up to him if he exercises the option to race for McLaren next year..
Yeh, because he was going to get sacked for your Stef  and he was tired of hanging around racing Manor and Sauber.   Very different if the car is half competitive and as a WDC you are not having to speak to your merits over a rookie
