Hi, just curious to know if my awd system is working correctly or has an issue that hopefully the gtr gurus could point me in the right direction if theres a fault somewhere. Since the only gtr ive been in is my own i dont have anything to compare it to.
Basically the 4wd light comes and goes as it pleases randomly for no apparent reason, but it will decide to work correctly about 50% of the time, would there be any reason for it to do this (system has been bled, no fault codes and tyres/rim are all the same sizes). Any possible idea?.
Also ive noticed that when the awd system is working it works completely fine when going straight but if cornering it seems that its all rwd, even under hard acceleration. Is this normal? Or have i got a fault somewhere?
https://www.sau.com.au/forums/topic/461736-r32-gtr-possible-attessa-issue/
There is a few threads in here you can search
My advice to most is a new Nitrogen canister (original is 25yo and very likely not doing it's job) and a new digital G Sensor (also very old and slow technology)
and if you want to go a good step further have the transfer case o'hauled and tightened up.
Cheers
  • 3 weeks later...
No, can be done with everything on the car (even the exhaust, although does make it easier) after 26 years mine was pretty tight and i had to machine a custom socket to get it off. using a g-clamp as i had read in another thread resulted in the canister unscrewing itself which could be pretty dangerous if the thing still had change, surprised they didn't make it with a left hand thread to avoid that ever happening. Was definitely worthwhile to replace the canister, overlooked by the vast majority i reckon.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
