So, this is my dilemma. They are hard to get a photo of, and can only be seen in certain light BUT they are everywhere.
the guy a bought it off used a Scourer to remove mould off the car. He left it sitting under a tree for nearly 2 years.
So my concern is, how much Clear/Paint is on the car.. i know these can easily be removed but i don't want to attempt it if there is a risk of causing a bigger problem.
I'm planning on the selling the car in 6 months or so.. So I'm hoping i can eliminate some of the issues. The paint is still shiny and looks great considering.
Also has some rust which needs attending to, most of it is easily repaired.. Couple of spots are of concern.
Or would it simply be better to not worry about the Scratches.
https://www.sau.com.au/forums/topic/461767-r33-light-scratches-everywhere/
Was about to say. Looks like someone hit it with a scourer.
You could remove a lot of those marks if you put in the effort with a cut and polish. But it has scratched a lot of the clear and will be making life hard for the next owner. So it really depends on where your morals lie.
That is why I want to get rid of them, I was unfortunate to not have noticed ( was a nice sunny day )
Who ever buys it shouldnt have to worry about it.
as stated I'm sure most will come out, just unsure how much i can cut it back etc
that's shallow scratches. good machine polish will remove them without taking too much clear off
the thickness can be measured but needs a $700 paint depth gauge, no point buying unless you are a pro detailer
Edited by junkie
Wouldn't a panel shop be able to do it just the once for you? Surely it would be better than having an expensive tool lying around never to be used again.
The tool will quickly pay for itself when looking at any cars in 'original condition and 'original paint' etc.
That is true, you could have it for years and only use it a couple of times but for those couple you will be pleased you bought it.
These photos were after a polish. Except the Polish I use is fine as, no grit etc. So maybe a more Hardy polish and a Wax may help.
Otherwise I'll hit it with the Buff, I'll just make sure Im using a light touch.
Once I clear this up I need to have a look at the rust
Panel shops are not detailers or "Paint correction" specialists.
  • Like 1
If you are desperate enough to know how much Depth your paint has, I'm sure a shop somewhere wouldnt mind having a look if they have the tool. Might cost you though.
Would probably be easier to either buy one yourself or just wing it though. I've decided to have a go on the boot. atleast it's an easy enough panel to paint or replace as there is heaps of white ones without my issue.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
