Hi I have numerous parts for sale they include:
R33 GTR
Standard Bonnet $500
Standard Sideskirts $230
Standard Mirrors $150
Standard Side Indicators $30
Standard Dash Instruments (34,803klms) $330
Standard Piping $150
Standard BOV's $140
Standard Fuel Rail $20
Standard Turbo's ( 1 missing rear wheel, no shaft play) $600
Standard Pistons $150
Standard Conrods $380
Standard Oil Pump $120
Standard Oil Baffle $50
Standard Dumps $100
Standard Cam Gears $30
Standard Cam Cover $100
Standard Ignition Coils $220
Standard Shifter $45
I ALSO HAVE OTHER MISCELLANEOUS PARTS:
Carbon Fibre 3D GT Wing $750
Nismo Stainless Carbon Fibre Muffler 3" Cat Back Exhaust System $600
King "Super Low" Springs $80
Nismo Rear Suspension $130
Blitz "BIG" Boost Gauge $150
Blitz Exhaust Temp Gauge $170
Blitz Water Temp Gauge $160
3" Catalytic Convertor $100
4" Catalytic Convertor $130
Pierburg 400Hp+ External Fuel PumpsX2 $90 each
R32 GTR Twin Gauge Dash Holder $150
Trust Airinx (blue)Twin Air Filters $90
HKS (Green) Twin Pod Air Filters $120
Greddy Twin Entry Inlet Pipe for single turbo $230
HKS 1.8mm Head Gasket $120
Standard R32 GTR Rear Wing $240
Nismo Fuel Filler Cap $50
Momo Corse Steering Wheel with Boss Kit $200
SMS ME ON 0400200179 :headspin:
https://www.sau.com.au/forums/topic/46181-gtr-parts-for-sale/
catalytic convertor 3" and 4" both are like new only used for pit inspection, they came off R33 GTR, exhaust by nismo is off R33 GTR stainless steel with carbon fibre tip cat back. will sell cat for $130 freight for item is 22.00 due to weight of item. Sms 0400200179 to complete transactions.
R33 GTR
Standard BOV's $140
Standard Dumps $100
Hi
Can you send me a pic of the R32 gtr twin gauge dash holder please to [email protected] Cheers Peter
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
