Yep I have the same identical exhaust as Luis, the Fujitsubo
Legal my arse..
I have that exhaust with Scottys dump and 100 cell cat there is no way it is that loud. You can hardly hear it until i am well and truly up it.
Have you conducted your test in accordance with the RMS specs, and ensured that there are no hard surfaces within 20 metres to reflect any sound?
There is no way the Legalis is 114db.
Legal my arse..
I have never heard a Fujitsubo get that loud.
I ran one on my previous M35 with an intake & dump pipe from Scott as well as a Kakimoto de-cat front pipe.
No chance in hell it hit 114db
My current VQ35 under full throttle with only the headers attached, sure.
I did the test at 5000 rpm, and the device was 1m away sitting on the driveway.
Exhaust was facing the street to so no reflecting surfaces.
I get 75 db inside the cabin.
With the windows down I get 85 db
Device is calibrated and gets normal conversation at 65 db so it's pretty good.
One thing... my cat is a single cell , if you get my drift
I'll get a 100 cell bullet cat, that should quiet it down a bit.
Also don't like the explosions of unburnt fuel on freeway driving.
This is what I have now.
Edited by conan7772
Thats a big suprise as i was suprised how quiet my Kakimoto Hypermega N1 is. Ill try and get cabin / exterior sound clip when i can. I also have the 62mm kakimoto silencer that can quiet it even more with no restrictions due to same internal diameter
Yeah but it will be loud and drony if made.
"if made badly or ignorantly"
I am getting a new exhaust made in the next few weeks. I'll try and post up how it sounds when done. I guess i could have just gotten a new dump / flex and joined the Fujitsubo crew but i like tackling things my own way with what i have at my disposal locally. Support the locals folks :)
If the bloke i am using's other work is an indication of what i'm in store for it should be a nice bit of kit.
  • Like 1
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
