think your confusing the drift prac at AIR with this 9krpm.
this is a open track day isn't it?
My car is no good for drift mate. It's a drag and circuit car. :)
It will be nice if we could all catch up and do a few laps at Lala
  • Replies 135
I'd ring and check if you guys are planning on going to a friday session.........
There was supposed to be one today, but as a certain forum member found out after getting there car fully prepped, its for cars racing on the sat. and sun. only
Id say at this stage November may be better than me rushing to get my car out there, then finding out i forgot something :D
Ive got a stackhat, (gunna wear me motogloves too for that non sweaty hand driving techinque :)), and a fire extinguisher...
All i need now is some of that wang power :O
Fellas Practise days are generally on a Saturday, On these practice days they have Bikes, Superkarts, Open Wheel and Tin Tops, you get 5 15-20 min sessions in the day.
Also there is a Modern Regularity comp, you get 1 practise and 5 heats and they are run on Sundays(not every Sunday) in conjunction with the Superkart rounds. In this comp you nominate a time and try and stick to it.
Check the Mallala website for all dates.
Darren
I think it will be more fun to attend the regularity comp as your runs get timed. The infrared beacon is switched off during open practice day.
I am keen for November as well. The weather won't too stinky hot and the track is not cold/wet either.
November the 11th would be much better.
The Improved Production National Championships are on 12/13th November, so I assume Friday 11th would be a private practise day for competitors. For the SA guys, the BSM team are bringing the GTR. Pop out and say g'day.
:D cheers :P
:) cheers :(
Awesome.. :)
I will have to give them a buzz to check if it is indeed a private practise day.
  • 1 month later...
Friday 11th Practice - Cars Only
Saturday 12th S.C.C. Twilight Races
Sunday 13th S.C.C. Twilight Races
I assume SK is down for the S.C.C Twilight Races?
I will be heading down to check it out if SK is down in Adelaide.
Edited by Cubes
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
