Hi all,
Just wondering how many of you out there has ever had an engine go on you, you know, big stuff like cracked pistons, ring lands, rod failures, valve gear problems, head gaskets, etc etc.
If you can state generally what level of tune you had (rwkW) and why you think it happened, it would interesting to know.
Looking forward to the horror stories!
Freebaggin.
https://www.sau.com.au/forums/topic/4625-whos-blown-their-rb-engine-and-why/
At the 4 6 & rotary nationals in Feb this year, I blew up
my RB26 engine in the R33 GTR.It had around 340 rwkw using
bolt ons like HKS 2540s,FMIC,etc, but the engine itself was
untouched. I did 2 back to back runs, which was silly cause it was
too hot & the oil system must not have been able to keep up.
It ran 11.5 & 11.6 and on the second run developed a loud rattle.
When we pulled the engine down, the no. 4 conrod bearing was
completely missing except for a wafer thin bit left welded to the
crank!It was amazing the whole lot didn't let go through the traps.Also the crank was bent 2 thou & one of the pistons had been bouncing off the head.Keir wilson(R32 GTR 10.5fame) bought
this engine, rebuilt it and ran 10.6 at drag combat with it!!
So, providing they dont throw the rods out of the block, they can
be rebuilt quite easily.On the same day in Feb, Keir was not so lucky with his R32.Oil starvation through the traps welded the crank to the block & KABLOOEEE.
I remember grabing Brenton's Adelaide Clutch ute & hooking down to help him.One of the safety guys came over & passed me a handful of bits off the track.One of the bits was a bit of the block
with san (part of the nissan) on it! What a mess.Other than the Head the whole thing was scrap metal.
Now we both have OS 3 litre engines with larger,baffled sumps.
Hope it dosen't happen again, but when you rev over 9000 rpm
nothing lasts forever.
:flamed:
Originally posted by adam 32
blew up my internally std RB20
too much boost from the T04 and not enough fuel!!
made around the 280rwhp mark i think before it blew
hehehe I told you dont tinkering with boost! :P:cool:
hehehehe... how is your car running now? all fixed I hope:)
cheers
Joe
Guest nismogtsx
I did a couple of valves in cyl no. 2 when the conrod snaped and left the piston at the top... LOL The next rotation the valves opened and they hit the fused piston.... The mechanic who rebuilt had to drill the piston out of the cylinder it was that well fused....
My main point is that with mods the cars run well, but i was doing 230rwkw all the time and the conrods were standard... Now their a Nismo part... Got them fairly cheap....
Guest nismogtsx
I totally forgot my point.
Anyway i did all the bottom end but didnt wait for the rods to come. I got too hasty and re built my motor with the original 100,000km conrods and they lasted 3 months... So thats not bad... But you need to have a weak point in every motor.... Because there's no such thing as bullet proof.....
NOTE: Build it stong and give it heaps when you wear it in so the parts bed in hard and are ready for a hard life....
  • 1 month later...
Engine 1: 145 RWKW T3/4 High Flow Trust FMIC..... Standard Fuel Pump....ang bang rattle rattle.... too lean....
Engine 2: Sheared the cam belt tensioner bolt and lunched the head.... I've been told someone may have replaced the cam belt idler bearing and overtightened the bolt??
Engine 3: Still running hard with 180 RWKW... new owner hasn't blown it (yet)
BIG chunk of #1 piston - down to the ring land - parted company with the rest of the piston, and played pinball inside the combustion chamber. Also broke the top ring and bent an end of it upwards. Amazingly, not outwards, because bore is totally unmarked.
I suspect a dyno run had it lean out and detonate at the top end (fuel pump incapacity), but no proof.
Had a mild build - T3/T4 hybrid, FMIC, only about 115 awkW.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
