hey guys,
i've got an r33 and last week the car lost so much power. when i put the foot all the way down, it just revs and basically goes nowhere. I've tried pumping it with injector cleaner, fuel system cleaner but nothing seems to work. If anybody has any ideas as to what may be the problem, could you please let me know.
Cheers,
Antony.
https://www.sau.com.au/forums/topic/46282-power-loss-in-my-rb25de/
its something to do with the clutch in the auto or it could be the gearbox i had the same problem with mine but it was a manual as soon as it got to 4 rpm it would go straight to redline without me moving and it was because the clutch was worn and it was slipping have it checked by a mechanic
i have the same problem with my car. Its a 92' r32 GTS RB20DE auto. Did u find out th eproblem and how to fix it? very keen on the solution, as i am a Noob. it is my first car, and its been this way since i got it.
although a bit of an increase in power as the engine warms up.
Also, there seems to be a new engine noise which has just recently come up. somewhere between 2-3000rpm theres a vibrating noise, which sounds like somethings loose.
Any tips on what it is or what i should do? mind you i am a Noob.
  • 3 weeks later...
I have taken it to a few mechanics but unfortunatly have had no luck. No one seems to know what the hell is goin on. Its got nothing to to with the gearbox, apparently, i thought it may be the coils, but its not them, the next thing thats gonna be looked at is the cat to see if its blocked or not. Either way i'll keep you guys posted. If any body out there knows of a good mechanic who knows what they are on about with skylines and are in melbourne, could you please let me know.
Cheers,
Antony
PS. Anut, my car is exactly the same, increases in power as it warms up, sometimes it even goes back to being normal, but as soon as it gets cold, it starts all over again, and i do get that same noise around that rev range. I am trying to get to the bottom of this.
ill have the afm checked out, but i was told that if it was the afm, there would be heaps of smoke coming out of the exhuast, as for the fuel, its using heaps more, im pushing it if i can get somewhere between 250 & 300 kms from a tank using optimax. I would normally get somewhere between 450 & 500 kms
Does yours make like a loud sucking noise at cold start between 2000-3000rpm BOTH when accelarating and just after when stepping off the gas? Mine does this and i've got the stock air filter and air box still, no pods (i know pod does this). And it stops doing it after the car is warmed up like at normal temp. Can there be an AFM problem, like its on its way out?
nismo_GTS keep us posted wat happen to urs ok.
Cheers
Mine makes that noise but i have a pod, i have managed to book the car in for monday, the mechanic reckons he's gonna need the whole day to find out whats wrong, we'll see how we go. I'll let you guys know whats goin on whatever happens.
Cheers.
The exhaust will make a snappy vibrating noise in N/A's and it has been layed down to a charicteristic of the engine, something along the lines of the cams, should be most prominaent around 2500-2900ish.
I had a problem with mine a little while back where the engine would cut out and react like it was hitting redline fuel cut, but would do it as low as 3500rpm, esp the hotter the engine became, this turned out to be the exhaust cam sensor. Which is a mitsubishi part (Mitsu sabotage!!) i wasnt happy because the very same time it stop working, was the same time my car was sitting on the dyno, i was very pissed off. My car hit top of 96kw @ wheels, but due to the sensor cutting out at 4000rpm, and anyone with an N/A knows this is where the real power only starts to build up, i had another good 2500-2800 rpm left to pump out my power figure, i was not a happy boy.
Cheers.
Hay man did u find out wat the problem is?
:D
Hey guys. This is becoming really frustrating. The last guy i took it to doesnt have any idea whats goin on. He suspected that it might be the cat thats blocked but after putting it up on the hoist and checking out the temperature difference from one side of the cat to the other wich was only a few degrees, he said its in good nick. I am convinced that is something to do with the exhaust. Im going to change the cat anyway on the weekend and clean the pod out.
Cheers
P.s I really appreciate all the tips you guys have been giving me so far, thanks guys
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
