Hi all,
I have a few items up for sale:
R32 GT-R OEM Rear Brakes
Price: $150.00 (pick up in Melbourne or post at buyers expense)
Reason for sale: upgraded to Alpha Omega Racing Brembo Brake Kit
NOTE:
  • The pads will need to be replaced
Garrett Boost Gauge
Price: $50.00 (pick up in Melbourne or post at buyers expense)
Reason for sale: This was mounted in the drivers' side circular vent and I want to reinstate the air vent and don't have a need for the gauge
NOTE:
  • What you see is what you get. I.e. this is the boost gauge, mounting bracket and cowl only. No other wiring etc. is included.
  • If you have an R32 OEM drivers' side circular vent and you are looking to sell it or swap for this item, I would be keen if it is in excellent / very good condition.
R32 Centre Air Vent
Price: $15.00 (pick up in Melbourne or post at buyers expense)
Reason for sale: replaced with new item
NOTE:
  • I replaced this item in my car as the vertical control on the drivers side of this vent is broken so the vent slats fall down.
  • This may suit someone who can repair this sort of thing or if yours is even worse
  • Nissan Part No. 68750-01U00
Please PM for further details.
Also available on other For Sale Posts:
HKS GT-RS Twin Turbos $1400.00 (make an offer)
R32 GT-R OEM Front Indicators: $150.00 firm
Cheers
Rob
  • Like 1
  • 1 month later...
  • 3 weeks later...
  • 3 months later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
