Yes I am aware of those results, the whole reason I bought that turbo was based on advice from 34geeteetee and Lithium. In my original post I actually reference and link to 34geeteetee's thread and you can see my posts in that thread too. So full credit goes to 34geeteetee and Lithium in terms of discovering/recommending that turbo.
Like I said, the first thing on my list of things to do with the car is get the boost leak fixed, but I have not been in a huge rush as until I get the alignment fixed up and fit better tyres I cannot put the power down anyway. All these things require me to spend more money on the car and will come in time as my focus has largely been on other things for the past few months.
Without the boost leak it may spool up quicker as boost won't be escaping. Will it spool up as quick as 34geeteetee's set up? Who knows. From memory he had a much newer/more advanced ECU which may have helped him. He also had a flex fuel sensor which might mean they could lean on it harder as it will detect exactly what ethanol content the fuel is. From memory he also had a plazmaman plenum and throttle body, although from what I have read this is unlikely to make the difference. My point is that there has been lots of time and $$$ spent on his car getting it to that level. With mine a lot of the parts such as the ECU, intercooler, exhaust, boost controller etc have been carried over from the previous owner's 250rwkw set up.
So the purpose of me replying to this thread was not to say that the setup I have is the be all and end all, but just to show a direct comparison from the old garret with tuneagent manifold to the HTA twin scroll. The new turbo set up has made a massive difference but there are obviously more changes that could further optimize the set up, as we know it won't hold boost and the turbo should be more than capable.
I was just driving the car as is, however re posting in this thread has peaked my curiosity again, so I will try and fix the boost leak issue once and for all and get it dynoed again maybe some time in October.
  • Like 1
Sorry for any offence man, there was none intended...
I'm extremely interested in your results a whole lot more so than others as I'm also putting a twin scroll rear housing onto a hta3076 on an rb25 and I'm having a very hard time choosing between the .83 & 1.01 a/r twin scroll housings...
It seems your the only person to have actually done it so far on an rb25 and posted real results about it so I'm getting a little carried away with myself about what the possible issue could be in your setup... It's all very exciting indeed haha
IMO First things first, instead of finding the "boost leak" you need to work out if the problem is actually a boost leak or a restriction or both or neither or shit intercooler or something else...
Are you running a cat? And what boost control do you use?
Hey, no offence taken. Just acknowledging that yes there is room for improvement on my set up and also that R34Geeteetee and Lithium were the ones to discover the potential of these HTA turbos on RB25s.
3 hours ago, Dose Pipe Sutututu said:
" he had a much newer/more advanced ECU which may have helped him "
That won't help spool, unless you're setting up anti-lag for launching on boost.
Hmm ok. When I was at the workshop that tuned the car about 12 months ago before the HTA turbo went on, they mentioned some feature or other in the newer ECUs (Link/Vipec I think) which potentially helped to bring the car on boost sooner. I can't remember what it was, but it was not anti-lag. Maybe that is not the case. If anyone has any ideas as to why it does not spool as quick as R34Geeteetee's then I am all ears. First thing will be to try and find out why it won't hold boost.
What fmic are you using? I didn't see.
Also there are ways to get the turbo on earlier like pulling timing out as it comes onto boost.
If you had anything else I could help but I no longer have the dinosaur fc logit kit.
The intercooler was on the car when I got it, but just had a look and it is a hybrid intercooler. It measures 600*300 so guessing it could be a hybrid gt2.
What type of boost controller are you running?
What's your exhaust system? Cats?
After I upgraded to a HKS gt-Rs, I was on the dyno converting my car to e85 and I looked at my curve vs some other gt-Rs results I had seen and I was underwhelmed in its response and ability to hold boost.... (Was using a blitz duel SBC for boost control at the time)
SO, while on the dyno we measured back pressure directly behind the turbo in the o2 port and found it had 4psi of back pressure @ 20psi of boost.
The steps I then took in the following months:
I installed a turbosmart eboost2, deleted the 100cell "highflow" cat and upgraded my standard oem manifold to a HPI manifold.
Then a re-tune! We picked up around 800-900rpm+ in boost response which resulted in more power earlier for a fatter midrange... There's a dyno below showing before and after.
The BLUE line is before the upgrades and the RED line is the final tune after the upgrades. (Ignore the fact that the blue line makes slightly more peak at the top end as that run was only done for the printout to win a bet with a mate... It actually made 393.9whp peak before the upgrades..)
All on an rb25 s1, pon cams, Ross forgies, gtr itbs, e85 etc.... HKS turbo had the standard HKS 14psi actuator on it...
Thanks for the tips guys. I will follow up. Will try to get a boost reference after the intercooler and might even try to get a dyno run with the exhaust off and see if that makes any difference and then I will know not only if the cat is creating resistance but the exhaust itself, as I am not sure on the actual model.
  • Like 1
  • 4 weeks later...
Yo man any updates? Hope it's all going well (:
  • 4 weeks later...
I had a look and could not find any boost leak. Took it back to the workshop and they said that there was no boost leak and that boost drops off because it is wheel spinning on the dyno, resulting in less load. They took a pic after the dyno run. I have lost interest a bit in the car to be honest.
I've not seen this thread, hate seeing nightmare stuff like this going on.
So a couple of questions - how does the car actually drive on the road?  Does it feel excessively laggy in the real world?   What kind of rpm does it start building boost at all (ie, start pushing a bit) and when is it "getting serious" in 3rd gear from a low rpm pull?
Next thing, if I read right - you've found that this car has had "lag" issues all the way through?  Like you've change manifold, turbo etc and it's STILL laggy and drops boost hard?
What fuel are you running?  And out of interest, where in the world are you?  A sinco manifold is unusual in Oz I'd have thought.
  • Like 1
Just got my new snail! Hta3076 with a brand new Garrett ni-resistant 1.02 a/r twin scroll rear... 9839ebcaecd3b2c76a2832f792c8aa4c.jpgf1157600bbc3d9a3f7e86999525b33e5.jpg
Can't wait to see what this can do!! Will be a while before it goes on as I need to upgrade my fuel system.... I'm getting a new manifold made while I'm at it and I'm going a bigger exhaust and new ecu also...
  • Like 2
Ohh.  That should be fun.  You just bought it?  It's probably an HTZ3076...
Yeah man just purchased it! Got it from a workshop in the US who had a customer come in and order two of them, put a deposit down and never returned..... It's been sitting in his shop in a display case for nearly two years hahah! I got it for relatively cheap considering what they went for when FP still sold them...
Is there anyway to tell if it's hta or htz?
  • 5 months later...
Hey dude did you ever get to the bottom of it?
  • 4 weeks later...
Hey
I was happy with how the car drove as it was. It was a massive improvement over the previous setup and no further changes were made. The car has since been crashed.
I will be trying to sell the car as is and if it does not sell, I will part it out. The car has some really nice parts on it and rebuilt gearbox with very low klms so I am sure someone can get some good use out of the parts.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
