Hi Lads,
Im after some advice. A mate of mine has an r34 GTR with 4.11 front diff gears. after some research it appears an r33 GTR diff looks very similar to and r34 housing/drive shaft flanges/ABS etc and are 4.11.
Is it possible to grab an r33 GTR rear diff assembly and bolt it in to the 34?
Edited by Godzilladat
R33 has different rear diff ratio to a 34. Because one has a 5 speed gb and the other a 6
Kafish? :)
I am assuming his mates 34R is not running and they have a 4:1 diff in the front and they are wondering if they can fit a 4:1 diff from a 33 to their 34. If the car is runing with different front and rear diff ratio, we would have seen an epic fail video :)
I know the diffs are interchangeable because I am about to do this conversion. If all goes well, I should get it done this weekend.
The gearbox it self has got nothing to do with the diff. From what people say, the first gear in Getrag will be useless after a 4:1 convo.
Hey Bob - how is it going?
R34 already has 4.1 front - just looking for a rear to match it.
This bloke :yes:
Its all done and was pretty much a bolt in deal. Just swapped over the rear cover to the original r34 one. As this 34 is not a Vspec we didnt have to deal with active LSD's.
to those concerned about short ratios with the 6 spd dont be. Around town the thing is spot on. Sure it might struggle down the main straight at EC but everywhere else its great.
For future referenc, a R32 diff can also be used if you are ready to stuff around.
- the R32 ABS rings are differnt. 46 teeth on both 32 & 34 but the gaps are wider on 34. So the rings have to be swapped.
-R32 short axles do not fit 34 centre - different spline pattern. Swap the axles around. Don't know if aftermarket centers resolve this issue.
Gearing not as bad first thought.
Speedo is understandably read incorrect values for speed.
Speedo is out as you say, understandably. I actually think the 1st gear is a little long with the original 3.54.
The r33 diff housing did have some additional mount points on the casting that we thought might be a problem but upon stuffing it in it didnt touch anywhere and had a minimum of 10mm clearance to the body.
will update once more kms are put on by the owner.
PS. the job itself is piss easy for a weekend warrior mechanical type.
  • Like 1
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
