Yup , early 2017 no pricing as yet but you can put your Oder through Nissan's dealer.
Thanks for the reply. I called Col Crawford today (Sydney GTR dealer- i have bought a new one from them previously) and they said they had zero information on it, nothing on when/price or anything.
Could you clarify who is taking orders? PM me if easier, thanks.
https://www.sau.com.au/forums/topic/463710-nismo-r35/#findComment-7699719
Spoke To Chris From Northside Nissan's Wanggara ( Perth ). Apologise I prob should've made it clear before, that Im from Perth
Anyway Chris reckon I can put the order through them if interested , no color, pricing or further informations until late November but def early 2017!
https://www.sau.com.au/forums/topic/463710-nismo-r35/#findComment-7699723
No one is taking orders yet, they cant until they have an official release from nissan au, im sure dealers will take a tentative deposit to get the first phone call i guess but i would defiantly just wait.
this is the only info released for a 2017 GTR so far, a teaser pick
debut march 23 so like 5 days to find out atleast some info.
http://www.autoguide.com/auto-news/2016/03/2017-nissan-gt-r-to-debut-march-23.html
Edited by GH05T
https://www.sau.com.au/forums/topic/463710-nismo-r35/#findComment-7699738
  • 2 months later...
  • 1 month later...
so has anyone heard anything further?  the latest whispers i have heard is the Nismo will be here in June 2017 (too late for my liking) however the Track Edition can be ordered now for December delivery.  No pricing released to my knowledge, anyone have an idea/quotes on pricing?
https://www.sau.com.au/forums/topic/463710-nismo-r35/#findComment-7761848
  • 1 month later...
So the local launch events are underway and we should see some reviews trickling through.
The track edition and Nismo have been confirmed, pricing for the track edition is $227k +ORC apparently (about a $35k premium)
No pricing on Nismo yet, but rumoured to be around the $300k mark, if not more
Edited by LSX-438
  • Like 2
https://www.sau.com.au/forums/topic/463710-nismo-r35/#findComment-7772056
  • 1 month later...
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
