Looking to get the best sound out of my RB3025neo without being over the top loud, have read heaps of threads, want some fresh opinions
Setup details- RB3025neo , 260poncams, topmount, GT3076, 44mm tial, E85, 3 1/2inch dump and 100cell cat, current 3 1/2inch catback with jap middle muffler and X force large oval muffler..
Options so far
1) Cut jap middle muffler out and keep rest of system
2) HKS hi power 409 catback
3) cut Jap middle muffler out and replace X force muffler with Magnaflow, then add second Magnaflow if too loud...
So which will sound best , will a HKS catback with restrictors still be a restriction if using E85??
Edited by AngryRB
  • Like 1
https://www.sau.com.au/forums/topic/463757-hks-hi-power-catbacks/
overwhelming responses, thanks dudes lol..... went with HKS hi power 409 biches.. will include go pro footage in build thread in couple months for those interested :thumbsup:
Edited by AngryRB
So is the only difference between the Hi-Power and the Hi-Power 409 the type of steel?
I'm potentially interested in the Silent Hi-Power as I'm coming from an exhaust that may have given me permanent hearing damage. Looking to improve upon that. ;)
I put the Silent on my car a couple of weekends ago. It is loud. Too loud for my liking, but you may like it.
Hmm. Not that YouTube videos mean much, but it seemed relatively mild. I am looking for a quiet exhaust. I want improved performance, but if it sounded completely stock, that would be fine by me. If this is too loud, what system would you recommend? Are any quieter?
I've been reading about all the quiet ones, and it seems as though the GReddy Power Extreme II, Kakimoto Regu 06&R, and the HKS Silent Hi-Power are the top of the heap for quiet. But everyone's opinions on the best one are split (usually people just say the one they have is the best).
Seems to me, though, that the the Kaki and GReddy are pretty restrictive. The HKS is 3.75" (95 mm). So it may be the best compromise if silent is the goal but want to be able to build up HP without restricting.
No you get one custom made to make power and be streetable
If that's the case, what specifications would you recommend? I'm in the US where about 99% of exhaust shops won't even know what kind of car I'm driving. So some direction would be nice rather than spending $$$ on trial and error. Thanks!
Picked up the HKS hi power 409, i was expecting restrictions but this doesn't have the expected 2.5inch silencers, i had to google about exhaust size measurements and correct me if wrong, you measure OD right??
post-70965-0-62176400-1460016293_thumb.jpgpost-70965-0-57843800-1460016320_thumb.jpgpost-70965-0-58788400-1460016342_thumb.jpgpost-70965-0-83736200-1460016363_thumb.jpg
Seems the smallest part is the bit that will bolt to the cat , which is 3inch , this continues thru the small resonator we'll call it, then its 3.5inch, then at the flange it steps up to 3.85inch which goes thru the cannon then 5inch tip...
So this could be loud, we'll have to see but a thought a JASMA rated catback has to meet a decibel rating?? but with a GT3076, top mounted, and 3.5inch dump, maybe it will be much louder than Jasma hey...
Edited by AngryRB
  • Like 1
Yeah that will be loud.
Did your have the silencer in the rear or middle or does it look similar to this?
I can put a large Xforce muffler in the middle or Magnaflow, so should be ok for a weekender...
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
