I am considering taking my 6spd RZ Supra (240rwk) :wassup: on the track, I have adjustable height suspension, front and rear strut tower braces and good tyres but was just wondering how Supra's in general go on circuits. I hear lots about them in Drags but not so much on the track. Anyone seen em on a track or even raced against em? Obviously a lot is going to come down to the driver but I'm just curious on your opinions...
Also what kind of modification to suspension/handling are usual for track work?
B :throwup:
https://www.sau.com.au/forums/topic/46446-supras-and-circuit-racing/
Hardly see any at circuits when I come to think about it.
I've seen one at Eastern creek and it was pretty quick. But there was one at Wakefield and it didn't fair all that great. But there's too much variables to say what's what.
true, but there is one supra racing in NSW state championships... improved production i think.. would have to look into it!
goes OK, not winning any rounds that i've seen! sure it could be done, depends on budget and competition etc..
are you thinking of just doing a track day, not curcuit racing?
Dont think Ill jump straight into any series :Bang: hehe
Looking to do track days for 6-12 months with the Toyota Club and if its for me Ill apply for CAMS Level 3 (Have Level 2 atm). Once I have that I look into what i want to do next. May keep the Supra for a road car and import a 96-96 RX7 from japan which has been modified stupidly as I have seen them go for $13,000 -17,000 landed in Australia. I would feel better racing a 13k car in a series given the amount of contact that seems to occur LOL.
Anyone in SAU racing in any series around Australia, Hill Climb, Targa, Production etc?
B :bscreen:
Hey Bepo,
Being in Melbourne you may know the Ice Supra - well Nige is supposed to be hitting the track with that soon (will be detuned from its current 570+rwkw's). His major concern has been brakes.
He's obtained a set of Porsche GT2 callipers to go on before he hit's the track. Maybe have a chat to him down at Ice?
SG I agree, wont be wanting to set great times first time out I just wanted to know what kind of things would improve the stability and reliability of the car on the track so I didnt either smash it or blow something up LOL.
Good point about the brakes snowman, it currently has the 97 mdl updrage discs and calipers and I am going to put performance pads on it and flush the brake system and replace with good brake fluid. Going to flush the radiator, clean the air filter and fit a new FMIC before hitting the track too.
Another racing question, the car currently has 17/45/255's Potenza's all round but given they are low tread I was thinking about fitting Toyo T1S's which I have heard good things about.
1. Anyone have any tyre suggestions?
2. Is 255 too wide on the front? Standard is 235 front and 255 back.
Bepo :)
How much are the Toyos, if they are reasonably priced then i jump at them as i have heard good things. If they are up around $500 a corner then id be going straight to Dunlop D01Js.
As for the Supra not being a good circuit car, i would disagree. They have a great tractable engine, the later models have very adequate 4 pot brakes, and they have good suspension setup.
I would think a Supra with nicely upgraded susp, a decent clutch and the usual exhaust, IC and ECU mods would make it a very quick car around Melb circuits like Sandown, Phillip Island and Calder. They arent as light as soem of the other RWD Jap cars, but look at the wheelbase and track of the thing...it would be a very good car for circuits like Phillip Island and Sandown.
By right they should be, F/R track and wheelbase have a nice geometry. Don't forget they hold the quickest time for the modified class around Nurburgring circuit. As I said before get your suspension setup properly and you'll be right.
What is the best way to determine the optimal suspension config if your not an experienced racer? Trial and error is the only way I can think of apart from getting a professional to do it? Just had a thought, might be able to find the settings for track use on the internet.....
Toyo T1S are $305 a tyre at Tyrepower which I though was very good!!
Thanks guys for the info and support, its given me even more motivation to get out there and have some fun :)
I'll post the specs and pics of my car once I pick it up tommorow!
Do SAU events allow other cars to come along?.... eg. Supra's hehe.
B :(
Since you are in Melb drop in to Centreline suspension in Thomastown, a simple wheel alignment will do wonders...and Chris will be able to give you great advice on a setup should any components be worn and need replacing.
.Do SAU events allow other cars to come along?.... eg. Supra's hehe.
Of course, last day at Winton we had 2 x R33 GTRs, 1 x WRX, 1 x R33 GTST and a TX5 turbo....so the more the merrier. Just keep an eye out on Vic Events :(
you could get a set of 16" rims at 225.. and fit the semi slicks used by commodore cup cars
only $250 a corner, thats if 16" will fit. that way you can have those tyres just for the track and spend less on tyres!!
Bepo the best way to go about not smashing is to use any instructors at the track day. They are always asking if you're a novice and want an experienced trackie to sit in the passenger seat and give some pointers.
Reliability, just make sure it's serviced and all fluids are correct levels or even a little above. I run an extra litre of engine oil, but it's a different engine. If anything seems suspect at any time just back off and head for the pits. You can never guarantee it will all be smooth sailing.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
