looking to buy a s2 r33 gtst front cut or whole car or even a straight rolling shell under 4 grand full car can have a blown engine/drive train as long as the body is straight as ive hit a roo in mine and need front end parts/front cut or a car to put my engine/drive train in dont care if it auto or n/a for parts only cosmetic damage really. located in Queensland preferably message me on 0408060008
Edited by kaspur2
https://www.sau.com.au/forums/topic/464622-wtb-r33-gtst-front-cut-or-full-car/
  • 4 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
