The mods they is will all ready has.
Front Mount return Flow so no cutting up the car
Nistune
Hks Type S gtr oil cooler
hks front pipe
hks TI Exhaust
650cc injectors
HKS Reloaded racing pod filter set up
more to come when i remember josh
mmmk i get what you are saying been told 230rwkw is what it would make was making the car to spoll fast i.e kinda wana do some trmac rally one days lmao. ah so would it spol faster then a high flow? Would it be possible to use a diff rear housing then .64?
Edited by Outcast
yea get what you are saying the gt2510 has been mach ined out to take the gt3071 so should be making more power then 210 with them mods no? P.S the turbo has been highflowed to fit the gt3071 so should make more hp right?/
Edited by Outcast
Its sounds like a bastardized mongrel turbo. You could buy it waste a few hours putting it on and tuning $ and then let us all know if it works out. I'm with Ben, hg highflow bolt on. Its proven and u know what your getting. But up to you.
Just drop the idea of using that bits and pieces turbo. It will be shit and give you lots of problems. Just buy a standard blown up R33 turbo and get it high flowed. It's a bolt on affair and will be oh so easy compared to this frankenturbo.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
