Event:
Happy Laps - Lakeside Park
Description:
A chance to get out on track for a fun cruise and have some om nom noms! Bit of spirited driving is allowed but it is still an event on a race track so a few rules need to be followed (see below). Breakfast will be served with bacon, eggs, beans and toast.
Lakeside Park
Date:
Saturday the 25th of June.
Time:
7:00 AM Arrival
7:30 AM Breakfast
8:00 AM On Track
Cost:
$35 for members
$50 for non members
Please note that this is a per person cost, any passengers are required to pay as well.
If you wish to come along to watch and not have breakfast it is free.
Requirements:
1. Participants must meet minimum age requirements for being on track.
2. The overtaking car is responsible for completing the overtaking move safely.
3. Overtaking is only permitted on straights, unless clearly waved passed by the car in front.
4. Overtaking move must be completed well before the end of the straight, and the car being overtaken must be given plenty of room.
5. Cars should not be more than 2 abreast at any point on the track.
6. Be aware of cars around you, in front and behind (and beside when being overtaken).
7. Do not assume that the car in front of you knows you are there.
8. Please pay cash on the day, no EFTPOS is available.
Lakeside Specific Rules:
9. No overtaking or cars side by side on the kink.
Payment Details:
Name: Skylines Australia Queensland Club
Bank: Westpac
BSB: 034 063
ACC: 354012
PAYMENT REFERENCE: Username&HappyLaps
https://www.sau.com.au/forums/topic/464963-happy-laps-lakeside-park-25062016/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
