2 hours ago, HKS28R said:
How do you guys compress the GoPro video to upload here? I got all my footage but need to compress it because it's huge
This!
when you find out let me know ha
Go look for the gopro software for trimming and editing.  Try to re-encode in h.264 or mp4.
I use videostudio x9 by Corel.  But this video was still 400mb
Thanks mate, I'll look into that this arvo as well
You need more track time Mr. HKS [emoji14] what was your best time? Car sounded and looked awesome.
Yes mate I know. That was my first time I've tracked the car and also first time on south circuit. I went to learn the car and have some fun. I definitely have alot of learning to do but I think I did ok for my first time, not the easiest car to learn on haha
I got a 1:09, i know not very good, I think I'll run less boost next time and focus on track work. A few guys there were great support, I appreciated that!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
