Hey guys I started pulling everything to do my water pump today and have gotten to pulling the timing belt. I have the cam marks lined up for the intake and crank however my exhaust cam is advanced by 1 tooth. I have searched a lot and read you can gain mid range by doing this. What is troubling me is if I retard the exhaust cam and make it so all the marks line up correctly is this going to throw off my tune? Will this make any other differences that I should be aware of? Mod list in signature any information appreciated.
https://www.sau.com.au/forums/topic/465502-exhaust-cam-timing-question/
Got the water pump and timing belt replaced, ended up just keeping timing marks aligned in stock orientation as fsm says. Weird thing happened though.
After finishing job I started the car to burp the cooling system, all was well started fine and idles smooth, however once it got to operating temp it's like a switch flipped...idle was super rough and when given throttle would miss and sputter. I made sure all alignment marks were correct when I buttoned it up and the car ran perfectly for around 15 minutes. I can't figure out what the issue is. I let the car cool down and even on a cold start its running rough. Any suggestions?
Edited by Ed.williams5
So an update:
Car idles but sounds like it has a miss. I went ahead and replaced the coolant temp sensor thinking that may be the issue however even with the replacement it's still running like crap.
I made sure that car is timed correctly at 15* btdc with tps unplugged, I did notice however when adjusting timing nothing really clears the stumble up whether I advance or retard the timing. I may see if I can find a known working cas to see if that solves the issue.
Either way I know it has to be something electrical because it literally started running like crap at the flick of a switch.
I'll look into that next kiwi. I am running ls coils at the moment however I was thinking and wonder if I hook up to my Ecu if it maybe can point me toward the issue too (running haltech platinum pro)
Update:
Don't know why I didn't do it sooner lol. Hooked up my laptop and pulled codes and a datalog. Had 3 codes 2 tps codes from when I was adjusting timing and 1 engine overheat code. Car was running in limp mode with as safety from ECU. Cleared all codes and car runs perfect once again. Was also able to verify my timing through the haltech which is right at 18* base so may go back and adjust it down ever so slightly to 15*. Thanks for all the suggestions and help everyone!
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
