Hi guys im trying to service my car and have been reading alot of posts as too what to fill and how to fill it however i havnt found many for my 99 r34 gtt
So my question is i bought some penrite power steering fluid and was wondering if i was able to mix it with the existing fluid in the car as the pentite is clear in colour and the resosvoir has pinkish fluid ??? Please help as ive been sitting here researxhing for the last 20 mins and cant find a solution
https://www.sau.com.au/forums/topic/465505-r34-gtt-power-steering-help/
If it says on the power steering fluid bottle you brought it is safe to mix, then it is safe to mix with existing fluid as a top up.
I've never had a problem topping up with other fluid that are top up compatible. after a while it's good to do an entire flush.
also power steering fluid shouldn't really disappear if you're losing lots you may have a leak worth checking the hoses.
In future, I'd save your money and just buy regular ATF.
Fill reservoir -> start car -> top up if needed and steer car slowly left to right, continuing to top up as required
You need to bleed all the air out of the system. For what its worth, they seem to be a pretty strong pump. When i put my new engine in, I ran the car up to temp and checked over it, forgetting all about power steering (was empty) ran the car for probably half an hour all up with no fluid (mind you I didn't turn the wheel) and the pump is still going strong today
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
