Hey guys back at it again trying to solve some problems.  Was driving the car the other day and ended up having it die on me while sitting at a stop light. No lights came on only thing that happened was the idle dropped down to around 400 rpm and when I gave it a little throttle to bring the revs back up it died.  Went to restart the car and had a very slow crank, first thought was the alternator must have finally home bad.
So I got the car home and put it on my trickle charger overnight. Tested my battery the next day and voltage was 13.2 load tested with a carbon stack tester and it passed with flying colors. Now when I went to crank to start the car it still cranked very slow and wouldn't start without having a charger on it. Once it was running checked alternator at idle and I'm getting 13.77 volts. Next thought was possibly a bad ground which I ruled out by using 2/0 cable with eyelets from batt - to engine block, ground is good. Went checking voltage drop while cranking battery is dropping from 13.2 volts down to 10.1.
My question is has anyone ever had a bad starter that would still crank or cause the battery to discharge while driving around?
Synopsis:
Car died and wouldn't start
Charged and load tested battery - it's good
Alternator putting out 13.77v at idle
Solid ground (verified)
3v voltage drop while cranking
https://www.sau.com.au/forums/topic/465899-rb25-starting-issue/
I once had a bad starter motor that would still slowly crank but was drawing so much power that the biggest 4x4 battery known to man couldn't turn it over quick enough. Your car stalling at the lights would lead me to be looking for an issue elsewhere but it could be coincidence that the starter is playing up at the same time. Sorry I couldn't be of better assistance.
A starter motor arcing across the armature will use up all juice the battery has to offer and still not work properly, plus it robs everything else of the power needed.  So your spark plugs would be only getting a very weak or no spark!!!
Trident that is what I'm leaning towards at this point...the fact of the burnt electrical leads me to believe the starter may be the root cause of my issues. I will post updates after I test the starter tomorrow though
So I verified what trident stated is what my starter is doing...brass bushing the armature rides in is worn out and is letting it rub across the magnets in the casing while spinning when it sees a load. Now for a new question
I read that you can use a starter from a 67 Datsun 411 part number 16210. I got one of the and all the bolt holespecially and everything line up casing is a little bigger but no issues.  I check the teeth on my old starter and it is 11 tooth the 16210 only has 9...is this going to be an issue? Seems like the gear count would have to be the same for it to not chew up the flywheel.
Could someone running this maybe chime in and verify it's not going to chew up the flywheel?
Edited by Ed.williams5
Hi there. i am new to the Skyline scene but i have some experience with Electonics.
You say the ground to the engine is ok but what about ethe Body ground? I do not know where they all are but there should be a gorund connection to the body also.
To test I suggest you get a jumper lead and connect the Negative of the Battery to a bolt somewhere on the cars body and see it the cranking improves.
Michael
Edited by msammut
spelling
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
