Hi guys. I have a stock 1997 R33 GTST. Recently I discovered my exhaust manifold had literally cracked itself in half. Thought I should replace the turbo's oil line while I was in there because it was a bit dented. I bought a cheap kit on eBay for just the oil line (specifically for my engine with the stock turbo) and it came with a new oil restrictor banjo bolt, which looks to be a smaller restrictor than the stock one. Stock one looks like 1.5-2mm while the new one looks more like 1mm. Should I run the new restrictor bolt or the original one?
https://www.sau.com.au/forums/topic/465975-stock-turbo-oil-restrictor-question/
Turns out the original bolt has the same size hole, just further in. I probably should have just run the original one in the first place, but it's all back together now and I can't be arsed changing it.
And nah, I just reused the original hardware. Car's only got 100k on the clock, it was all pretty fresh. I just picked up a used manifold for $30, got it machined, and put it all back together with some MLS gaskets.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
