Hi guys,
I recently bought this turbo kit from a friend though I've decided to sell the car and I no longer require it.
Below is the link to the previous add by Brett (REAPER) who was selling it for 7k. This a magnificent kit and will not disappoint. Id love to use it but circumstances have changed and the car is now being sold.
Im asking for 7800 as I paid more then 7k with the Tial waste gates now included. Negotiable on the price if you don't stuff me arond. Kit is available without gates at a cheaper price if desirable.
located Sydney
0432528844
Thanks
  • 1 month later...
F/S R33 GTST series 2 stock suspension and sway bars***********
Hola
Up for sale is a full set of stock R33 GTST series 2 coil overs. The boots have seen better days and the bushes are a bit worn but there is no leaks and would be perfect for someone who needs to pass rego or clear a defect.
even perfect as insurance for the day you might get defected.
Also have the front and rear sway bars.
Located Sydney and can post at buyers expense,
Coil overs $250
Sway bars $100
Cheers
  • 3 weeks later...
  • 3 weeks later...
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
