Hey guys
Probably been asked a few times but everything i find/get told is different to each other..
So i'm trying to find out what turbo is on my rb25det. In r32 skyline
When I purchased i was told it was 'highflowed'
Later discovered the car was running a nistune i got my curious and started pulling apart intake pipes, manifolds etc to find out whats been done.
Ok so ive been told its a 28/71...
But want more info/confirmation
Or someone i can take it to in Melbourne that could help
Cast in Front on turbo compressor:
GARRETT M24
Cast on turbo housing at the back:
HKS 064
On the center tag:
Top: GARRETT JAPAN
Ki 0216J
Bottom numbers:
446179-5032
Someone please help...
https://www.sau.com.au/forums/topic/466284-help-id-this-turbo/
Unfortunately i have no idea man..
I brought the car as stock rb25 with a highflowed turbo
Then discovered the Nistune and now turbo
If i put a stock ecu in, it throws a nock sensor code and idles extremely rough and rich
Nistune only runs 1 knock sensor and it idles and and drives very smoothly and it doesnt smell like it runs rich, yet to calculate fuel consumption
Will be getting it to a nistune tuner as soon as everything else is sorted
Probably an RB20 ECU that runs with the nistune and apparently most nistuned RB20 runs entirely on the knock map so the tuner copy the main fuel and ignition maps into the knock map and it runs normally. Mine is setup like that, it constantly runs on the knock map with or without the knock sensors plugged in, even with the 1M resistor shunt to ground to replace the knock sensor. The ECU doesn't throw any code but still runs only on the knock map.
What is your ECU reference ?
According to my notes 446179-0032 is a 56 compressor trim GT2871R cartridge .
From memory what you have on the cold side is an early HKS type machined inlet shroud which they used on the RB six cylinder versions of their 2530Rs 2535Rs and 2540Rs . The GTRSs had a unique port shrouded compressor housing on the RB versions and the four cylinder versions had a Nissan/Garrett style compressor housing . The RB version used a 52 compressor trim version of the 2871R . I think the 2530 cartridge number was 446179-0021 , the 2535 446179-0019 , and the 2540 446179-0018 . I think the GTRS cartridge is 446179-0067 .
To me it looks like someone had a HKS spec turbo and hi flowed it with a Garrett marketed 2871 56T cartridge .
A .
Edited by discopotato03
  • Like 1
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
    • Wife and I are still looking for a new home. One condition was a large enough garage for a full-size lift in one bay. Now if only we could find something... We've been looking for almost a year now.
    • Thanks everyone for the ideas! Sadly, ramps are a no go for me. With young kids at home, I do most of my work late at night while they're sleeping. Starting the car multiple times wouldn't be a great idea.  I'll go see one of those new long reach low profile jacks and take a couple measurements to see if they will fit.
