I have a issue when ever I sit at a point on the peddle over 70kmph. It feels like it's jumping a little or slipping. Slip,grip,slip,grip ect only when I cruse if I give it a little or back off a little it stops.
Changed o2 sensor and plugs got spitfire coil packs nistune return flow cooler running 11psi stock everything else.
Any advice or thoughts please guys thank in advance
Got 1000cc injectors & 460 Walbro.
Going to unplug the o2 take it for a spin to make sure I didn't remove the busted one replace it with a dud.
Thanks I will check out all these things post what fixed it.
  • 2 months later...
Question is then.........is it fuel/spark related or a clutch/drivetrain issue? CV's, TPS, CAS, clutch, axle, diff - its hard to keyboard tune I think!
You said that may have been the issue way back. [emoji106]
I am swapping out the stock replacing with 1000cc mid next year. I'm pretty sure that will resolve the issue.
  • 4 months later...
Finish off this thread, I put new tyres on rear a bit before never occurred to me months later when I noticed it. But today I rotated tyres got all rebalanced problem gone. I think someone mentioned tyres way back in thread.
Thanks guys
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
