Hi all,
I am in the process of trying to confirm the kms on an R33 GTR that I am interested in buying. The seller does not have any of the normal import documentation (auction sheets, de-registration cert or a Jevic Cert). Normally in my buying process this would be the end of my investigation on a car and I would move on. However, the seller seems to believe that the NSW RTA holds copies of this documentation when the car is registered for the first time.
So my question to you: Does the NSW RTA hold copies of the original import documents when a car is imported into NSW for the first time?
I personally can't see this as being the case, however i thought I would throw this question out to a wider audience, as maybe, just maybe, someone out there has had a similar experience and can confirm one way or the other.
I'm in Victoria so have no experience with the NSW RTA. I have emailed the NSW RTA asking these very questions, but if they are like VicRoads, I could be waiting a while for a response.
Any light people can shed on this would be greatly appreciated.
Ah, that's some very handy information. If i'm not mistaken the compliance shop should be on the sticker. So I should be able to back track these details if I put in the effort (which I'm starting to wonder about). I'll let you know what I come up with.
I can't say I have, I didn't know they existed. I will take a look into this. Thank you very much @Terry_GT-R34.
I'm still waiting to hear back from the NSW RTA (so at least they match VicRoads in that respect). I'll post up anything I hear back for future reference.
I have heard back from the NSW RTA via email:
Quote
Dear Mr. Wood
Thank you for your query.
The Roads and Maritime Services (RMS) receives all odometer information from third parties, such as from vehicle inspectors during 'pink slip' inspections, and from motor dealers during the process of purchasing and selling vehicles. The accuracy of odometer reading information depends on the accuracy of the information that is provided to the RMS, therefore the RMS cannot independently verify whether odometer readings are correct.
It is for these reasons that the RMS does not provide odometer reading information to the general public.
If you suspect the odometer may have been tampered with it is suggested that you contact NSW Fair Trading for further investigation.
So in summary, the NSW RTA will not release any details regarding an imports first odometer reading. So I think as mentioned by Terry above, the best bet will be to go with a Japanese History Check or Japanese Odometer Check.
I certainly am learning a lot about imports considering I don't own one yet. :)
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
