Hey everyone!!
As you all know once you buy a GTR you will end up broke but that's the fun of it hehe ;)
Well it's a 33 gtr, just recently the hg let go after getting it tuned!! All the car had is a full exhaust and adaptronic ecu. So it's time for upgrades :)))
So far I got the stock twin turbo off and pretty much I broke every single pipe bolt etc ( it was a night mare). Now slowly taking the intake side off and then head off!!
Mod list:
Bw s300sxe (8376 - 62mm) ts .91
Ts 6boost mani
Turbosmart 50mm ext pro gate
3.5" tbh (no cat)
4" intake pipe
avcr boost controller or I can use the ecu to control the boost ( which one is better)
fmic 100mm
3" intercooler piping
Bosch 2000 cc injectors (any issue using them on e85)
walbro 460l fuel pump ( thinking of going 2 in tank pump setup)
turbosmart fuel reg
tomei hg 87 bore and 1.2 thinkness with intake n exh as well
tomei type valve springs
arp head studs
tomei 1.5 oil restrictor
new radiator and also all the hoses are getting changed
im getting the timing done with all the seals etc
setting up an oil catch to control the oil better.
hopefully will reach the 400kw as the motor still stock but will see how far it will get to before it blows up.
i will be taking pictures as I go so hopefully everything will turn out to be good.
any suggestions or tips to help please let me know.
i hope you guys enjoy it
thanks
  • Like 3
https://www.sau.com.au/forums/topic/466448-33r/
  • 3 weeks later...
Can you pm his details?
i have been very busy with work didn't get much time to work on it. Also wtac this weekend so hopefully sometime next week I will do some work on it.
Also waiting on a new oil temp sensor as I've deleted the oil/ heat exchanger.
Rocker covers and intake getting painted next week.
Hopefully a week or 2 and everything will be done.
Good choice on the turbo bit expensive good luck with everything... everyone seem going with bw8374 the response is amazing!! How long until you will finish with your car?
cheers
https://www.sau.com.au/forums/topic/466448-33r/#findComment-7783517
  • 5 months later...
So finally got the car done!!
It made decent power.. 458rwkw @ 28psi
Long story short the engine let go after 1 week
Time for rebuild
Power goal 600-650awkw
I wan do things once not twice so
Trying to decide between a stroker or stock displacement
Head work
Fuel system etc
Basically any tips or help will much appreciated
https://www.sau.com.au/forums/topic/466448-33r/#findComment-7820855
  • 1 month later...
  • 1 month later...
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
    • I didn't actually try it at the time but a Launch X431 with the appropriate software licenses/upsell will have the ABS bleed function. The Consult II you can still find some old sets of equipment but they're really, really expensive:
    • Well I'll start by saying I'm not an engineer. I am going to go with the KiwiCNC ones.  They are made of 7050 alloy have good fillets and radius.  The material alone is in the order of double the strength and fatigue resistance - Those bolts, once torqued correctly place most of the load at the flat face of the mating surface - the 'stretch' you're talking about through torqueing them up would be far more than the extra stretch 'load' placed on them from a steering input or bump. (in my opinion) so I doubt they would flinch.    - but again "not an engineer".      oh and I don't think stitch welding 7050 is a good idea, likely just weaken the material (from what I read)
