At the moment I get 400-450km per tank from my R32 GTS-T and that's running normal petrol (Mum filled the car up for me put the wrong one in - ah well). I will be putting Optimax in the car after this tank runs out and also adding some octane boost.
I wanted to know if I install a SAFC, either 'Greddy e-manage' or 'Apexi SAFC' and have it tuned so the car runs leaner, but not lean enough to cause detonation.
Will I get better fuel economy by doing this?
Also keep in mind that I use it as a daily driver and don't race around it in.
https://www.sau.com.au/forums/topic/46662-safc-better-fuel-consumption/
Potentially yes, in reality NO
Once you benefit from the extra kw from a better fuel curve, your right foot will suddenly get a lil heavier...
Most tuners only go for a leaner fuel curve at WOT, and don't bother tuning at low throttle. So in terms of better fuel economy it kinda cancels itself out b/c it only happens at WOT....
If you ask your tuner to tune it at low and High throttle positions, you will potentially see some better fuel economy for everyday driving, but I would say the difference would be close to negligible.
Hi Guys, the later versions of the SAFC have separate WOT and partial throttle tuning. By the time you tune these 2 ranges and add them to the standard ECU closed loop running, you have a pretty good recipe for the best fuel economy your right foot will allow. After tuning the SAFC, the average change in A/F ratios at WOT is between 10% and 20% leaner, the partial throttle is between 5% and 10%. Since the improvement in A/F ratios also results in more power (typically 10%), the theory is if you drive at the same speed and accelerate at the same rate as you did before the tune you could end up with between 10% and 30% fuel economy improvement. So MICR33 is doing pretty well to get a 25% improvement (from 400 to 500 k's). :D
So it is worthwhile telling your tuner that you want him to tune the SAFC at both WOT and partial throttle openings, you will get the extra tuning costs back pretty quick. :)
Hope that helps :)
Hope that help, hope that help....
That was great, that's exactly why I like using forums to get gold information like that, thanks heaps SydneyKid. I am in Canberra so I just have to find someone who is able to do this for me and not charge me heaps of $$$
MICR33 -
Just so I know what mods do you have?
what boost level?
What controller are you using?
I don't have the mods on anymore as I'm selling the car, but this is what I had:
Full 3.5" exhaust with a HPC coated dump front/combo pipe (this has a separate wastegate pipe that rejoins further down the exhaust).
SAFC tuned by Hills Motorsport
HKS Type S FMIC
Stock turbo, 1 bar by a bleed valve.
HKS exhuast cam gear set 2 degrees retarded
Fully boxed Trust Airinx pod filter with a cold air feed.
NB I do a fair bit of highway driving, so that would have given me higher actual values than most people can expect. The 25% improvement in fuel consumption from whatever you get now, though, should be about right.
BTW I'll be selling the cam gear, front/dump combo pipe, pod filter and box in the near future if you want them. I haven't worked out how much I want for them all though.
O8Elf - try changing your fuel to BP Ultimate!
Good reasons why if you search!  Give it a go and see what you think!  I use to use Opticrap but since switching to Ultimate Im much happier with the car!
Since the Ultimate you are using comes from the Shell Refinery at Clyde, same as Optimax, I am surpised. If you want to check this, go the the BP web site (www.bp.com.au) it tells you where your fuel is made and who makes it.
Save you the trouble here is the quote....
A particular feature of the Australian oil industry is the practice of refinery exchange, in which refining companies exchange products in various locations to minimise distribution costs. For example, BP supplies other companies in Perth and Brisbane and in return is supplied with product in Melbourne, Sydney and Tasmania.
Possibly a little off topic ...
How different is SAFC and PFC in terms of fuel economy?
I believe PFC is open loop, yes? So assuming you are comparing freeway driving, I'm guessing the PFC would end up worse off (and thats assuming same throttle position on the highway, but when its the M1 on a saturday night, sif that happens)
Our fuel economy went very far down when we got the PFC + AVCR because the tune was so rich to stop pinging (still ended up losing a fair bit of timing). Now with a cooler, the timing is back in and the tune is good and we've gone back to pretty much standard fuel economy for us, which is about 7.5k/litre combo driving.
Hmm, FWIW ... We run Optimax religiously, but a while back we trialed Ultimate after reccomendations from a gtir owning mate of ours. It didnt idle properly and had a miss around 2500rpm. I dont know if we simply got a bad batch or two, or wether the remenants of the Optimax mixing with the Ultimate made a Funky Fuel, but we've now gone back to Optimax and havent had a drama.
Just a thought *shrug*
I believe PFC is open loop, yes? So assuming you are comparing freeway driving, I'm guessing the PFC would end up worse off (and thats assuming same throttle position on the highway, but when its the M1 on a saturday night, sif that happens).
PFC runs closed loop, so the economy depends on the tuning and the right foot. :)
"WOT is wide open throttle." hehe, that's like saying How Long is a Chinaman ;)
Anyway, about S-AFC etc. I've noticed that upgrading my ECU gets me both more power and better economy, using similar driving habits. I went from 150rwkw and 15-16L/100km to 166rwkw and 13-14L/100km with a tuned S-AFC (0.8bar for both these), to 14-15L/100km and 215rwkw when retuned to 1 bar of boost and cooler upgrade, to my current ~215rwkw and 13-14L/100km with PowerFC and 0.8 bar of boost. The only thing now is my highway economy is slightly worse than it used to be, but that's because I haven't had it tuned yet. I know you should tune it as soon as possible after installing it, but my knock levels are so low and the car is running so great that I've put it off until I can afford an AFM upgrade (it's now maxing out at 0.9 bar, and it never maxed out even at 1 bar before with the stock ECU).
Well call me crazy, but I did make an unbiased comparison and noticed smoother gear shifting with the auto and better economy with the same conditions.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
