  • Replies 102
My spot is up for grabs
I will have to pull out as my clutch is starting to slip
May not have it fixed in time.
Will still come to watch thuo.
I'll scam said spot if its still available Erin!
When you deposit money, please send me a pm to let me know. Someone deposited money yesterday and I don't know who it is :S
Thanks!
I will also ask that if you DEFINETLY want a space on the day, to please deposit the money into my bank account. I have got quite a few people pm'ing me asking for spots.
When the day comes and you've put your name down, but haven't paid, and others who have the money waiting to pay will be given the spot.
